Pioneer AX10 owners, can I have help on size?
Discussion in 'AV Receivers & Amplifiers' started by Gadjet, Aug 13, 2002.
Tags:
  1. Gadjet
    Gadjet
    Aug 14, 2001
    411
    Wrexham
    +7
    I am trying to buy an audio stand to place all my equipment on and one is the Pioneer AX10. I am still... waiting for this amp to arrive from Sound and Vision so thtts why I need your assistance. Most of the units do not have enough depth.
    Could you help by telling me how much in mm, space will I have from the back "feet" to the back of the machine. This will help me in being able to buy a unit with the back end of the amp over the shelf but all the base feet are still placed on the shelf.
    Your help, as always much appreciated,
    Phill
  2. Xyberbat
    Xyberbat
    Jul 30, 2002
    Knegsel
    Distance from rear of feet to backend of main amp body is about an inch (25 mm) ; speaker terminals protrude about 3/4 inch (20 mm) more.
    Good luck with your search - I had to build a custom cabinet.
    François
