Pioneer AX10/AX10i
Discussion in 'AV Receivers & Amplifiers' started by mystex, Aug 26, 2003.
Tags:
  1. mystex
    mystex
    Sep 15, 2001
    108
    Brighton
    I'm very close to purchasing one of these amplifiers, but I need to know whether either one has an audio delay feature to combat lip sync problems? I've hear some people say they have and others that they haven't! If they don't then I might consider the Denon 1SR.
    Thanks in advance.
  2. dennis
    dennis
    Jul 2, 2003
    1,239
    surrey
    +54
    yes it does,and you wont regret getting one! it's awsome but dont give yourself a hernia lifting it.:D
  3. mystex
    mystex
    Sep 15, 2001
    108
    Brighton
    Thanks for the reply, that was the only thing holding me back. I don't suppose you happen to know whether the AX10 (older model) has the feature aswell? Thanks again....
  4. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    The new AX5i also has an audio delay feature if you want to spend a bit less!
    Steve
