Pioneer Avs Internet Radio Help Needed
Discussion in 'AV Receivers & Amplifiers' started by rollinson1, Sep 9, 2012.
Tags:
  1. rollinson1
    rollinson1
    Dec 10, 2010
    96
    11
    Dudley
    +6
    Hi, I play internet radio quite a bit but seem to be having a problem with a couple of stations I play regulary. After listening for 46 seconds the station stops playing. If I use the same stations through shoutcast on my Bluray player there is no problem. My amp, a Pioneer Vsx Lx53 is connected via ethernet cable so should not lose connection but as other stations play ok I cant see there being a problem with the cable. Any ideas would be welcome.
    Thanks Paul
