M
mecon
HELP!
I am having a problem with flashing HDMI light on my Pioneer DV-696AV when connected to my Samsung LE40R73BD via HDMI.
I had the HDMI cable checked in the shop and it's fine with another setup. I also tried the Pioneer reset as stated in the manual. Still the red light keeps flashing.
I contacted Samsung, they said it's definitely a Pioneer problem. When I contacted Pioneer, they said I should take it back to the shop and ask them to connect it to a Pioneer plasma and see if it works. The problem is the shop I got it from does not stock Pioneer plasmas, also even if it works, I do not have the budget for a Pioneer plasma!
I read another thread in this forum that someone has a problem with the 696 and another model of Samsung lcd tv and it was corrected by playing an SACD in the player. However, I don't really see how this is going to change anything, also I don't own an SACD.
Does any one have the same setup as me? Please I would like to hear if you have the same problem or not.
Thanks.
Thanks.
