Pioneer 908 upgrade to 7.1 ?
Discussion in 'AV Receivers & Amplifiers' started by tiberious, Dec 8, 2000.
Tags:
  1. tiberious
    tiberious
    Anyone know if there is an additional "box of tricks" I could use with the 908 receiver(DD and DTS 5.1) to get the extra surround channels (6.1/7.1) ? - worth it ?
    all input appreciated as always
  2. Guest
    Does your Pioneer have pre-amp outputs?
  3. Boris Blank
    Boris Blank
    Aug 7, 2000
    1,772
    Outpost 31
    +215
    I'm sure I saw what you ar looking for at Leconcepts.com, an A509 or similar. About £250 as I recall. Check the details first as it may only be suitable for particular models.
    Paul
  4. Colonial Marine
    Colonial Marine
    Dec 8, 2000
    37
    London, Uk
    In issue 62, November 2000, of HCC page 80, there is a "Smart CS3XJr" it appears to give you the extra 1 or 2 channels that you want. Cost quoted at £400.
    I say we take off and nuke the entire site from orbit.....it's the only way to be sure.
  5. tiberious
    tiberious
    thanks guys , I`ll check those out !
