Pioneer 868 to sim2 Domino 30H
Discussion in 'Blu-ray & DVD Players & Recorders' started by m0v1em4n, Aug 12, 2005.
  1. m0v1em4n
    m0v1em4n
    Jul 1, 2001
    819
    Derby
    +48
    Hi all,
    I seem to have a problem
    I have connected my Pioneer DV-868 AVi to my domino 30H via HDMI and i am getting green flashes every now and then
    possibly every 30 to 60 sec any one have any ideas?
    is the some setting i have wrong
    Steve
  2. sbowler
    sbowler
    Mar 24, 2005
    3,795
    Leeds
    +487
    I assume you have checked to make sure its connected correctly and no breaks or cracks in cable, can sim2 accept
    HDCP signals. is the flashing present on any other cables. are there any devices which could be causing interference.
    also could you try and loan another cable from a dealer and test it to see if the same effect is present.
  3. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,517
    Edinburgh
    +1,239
    Definitaly sounds like the HDCP handshaking is dropping its connection. This can be caused by a faulty cable, a poor quality long cable, loose connection on either socket or finally it could be that the signal strength from the Pioneer's output is not sufficient for use with a long cable (if that's what you are using).
  4. m0v1em4n
    m0v1em4n
    Jul 1, 2001
    819
    Derby
    +48
    Thanks to all that replied I think one of the ends seem loose
    I now have a new problem, I factory reset the Pioneer 868 in an hope to get some resolve, and now when I plug it in to my Domino 30H it crashes it,
    cant get to the setup on the 868 to set the HDMI :suicide:
  5. Geordie Bry
    Geordie Bry
    Jun 27, 2004
    1,015
    +59
    hi there iv got a pioneer 868 connected to a screenplay 7205 i use a chord company hdmi which is 7 metres long with no problems at all
  6. m0v1em4n
    m0v1em4n
    Jul 1, 2001
    819
    Derby
    +48
    Ok some more info on the 868,
    Manage to connect the 868 to a TV via DVI,i get the Pioneer logo at the start but the blue HDMI light on the front just flashes and the screen flashes as well,
    steve
  7. Geordie Bry
    Geordie Bry
    Jun 27, 2004
    1,015
    +59
    u will need to get into set up menu to enable hdmi make sure there is no disc in the tray
