Pioneer 868 - Questions re: HDMI
rimibar
I have an Optoma H50 projector, and would like to know whether it can process the HDMI output offered by the Pioneer 868?
I don't really understand how it functions - this may well be a stupid question, but any help gratefully accepted!
Thanks in advance,
Richard :smashin:
G
Garnot
Originally posted by Docta teef
I was looking to do the same with an H56 and the 668 I was informed by seven oaks that the 2 would not work together as the H56 is not an hdmi input but a DVI-D as is the H30
HDMI and DVI-D are fully compatible regarding to video. The difference is that HDMI also carries Audio and DVI-D only video. The possible problem is that the Optomas aren't HDCP (High Definition Content Protected).
HDMI and DVI-D are a 2 way comunication connection between the source (DV-668/868) and the display device. If both are HDCP, then they'll communicate. If the Optoma is not HDCP compliant, it won't work with the Pioneers 668/868 or the Denon A11.
Matthew J Taylo
Garnot,
Does this mean that if I want to connect my Pio 868Avi-s to a plasma via DVI & not HDMI all I need to do is to check to see if the plasma is HDCP compliant?
I want to see if I can connect my Pio DVD player to the Panny 6 series plasma as it's much cheaper than the Pio 434 & the PQ I've seen is great?
Kind Regards
Matt
Dutch
Matthew,
The DVI blade for the Panny series 6 is HDCP compliant, so it will be compatible with HDMI. Have you seen the SD or HD version? Be aware that the SD version only has a 480 line resolution so there wouldn't be much point in using the 868's scaling capabilities. Hope this helps.
Steve
G
Garnot
Originally posted by Matthew J Taylo
Garnot,
Kind Regards
Matt
Matthew,
Wether it's HDMI or DVI, it should be HDCP compliant. If it is, it will work.
Matthew J Taylo
Hi Dutch,
Blade? do you mean the connector?
SD or HD? how can I ensure that I'm buying the right plasma?
Finally, do I simply purchase a DVI-D cable & plug this directly into the 868AVi-s & then directly into the Panny? I'm not sure if you can purchase a DVI board for the Panny?
Apologies for all the questions
Matt
hornydragon
HD panny has different model noPWD6 instead of PW6??? cant remember off the top of my head. HD either comes with DVi or you can buy the card, defo available but not sure, not at work so dont have info to hand mate. MAW will know tho.
uczmeg
Originally posted by hornydragon
Anyone know if samsung DVD will work on DVi input of none HDCP displays?
I had a non HDCP projector and used it with the 935.
I got a signal in 720p mode despite the manual saying I shouldn't have been able too.
Marc
Nic Rhodes
I am not sure all the advice being given here is entirely accurate :). DVI and HDMI are NOT the same, similar yes but certainly not the same. My post on digital interfaces might help here. For starters HDMI can be 14 bit as opposed to 8 bit DVI! (just a small difference, for the future) but over looked by those rushing to claim they are identical
It is not just a HDCP issue but also what DVI can do. DVI is a 'computer' interface, HDMI is an AV interface. What I really mean is that most DVI inputs don't accept anything (like RGB Inputs nowdays) but only a certain few frequencies. 480p fine, but try and get many to understanf 576P and they often play dumb as it is an AV format and not used by 'computers'.
It isn't just about HDCP it is much more complicated. My digital interfaces thread should give you all you need to then ask the sensible questions to get the right answer from manufacturers.
G
Garnot
It's entirely accurate regarding to DVD players digital outputs. You're right on that HDMI is capable of a higher (12 bit) bit per component YCbCr. HDMI can go as far as 1080p contrary to DVI. But at this time, the DV-868 is sending 8 bits per RGB channel (Bbit X 3 = 24bits) when connected with a DVI-to-HDMI cable.
There is a DVI version for computers but the DVI-D version we are talking here is the A/V DVI-D version. When we talk about A/V (Home Theater) DVI, is about the DVI-D connector.
rscott4563
DVD is limited to 8bits per colour channel isn't it, therefore not capable of taking advantage of any further benifit HDMI may have over DVI.
Also on the subject of resolutions, apart from the fact that DVI can't handle interlaced resolutions, isn't it actaully down to the EDID information in the DVI input board that would limit the accepted resolutions not the actual technology itself, as with the Panny DVI board for its plasmas, people seem to be having issues getting it to accept a native resolution, but someone (can't remember their name) has managed to reprogram the eprom to tell it to accpet the native resolution. So as long as the manufacturer has programmed the DVI input properly then there should be no problem accepting a HDMI input..
Ryan :smashin:
G
Garnot
Ryan :smashin:
Ryan,
The problem is that we know what's doing the HDMI output DVD player when connected to a DVI-D display input. HDMI & DVI-D are a 2 ways communication connectors. The source will receive the signal from the display to go ahead as a DVI-D format (8bits per color channel) when connected in that way. I'm not sure if the Pioneer DV-868 is sending 10 or 12bits when connected as HDMI-to-HDMI. I won't asume anything here.
By the way, HDMI/DVI are capable of any interlaced or progressive signals up to 1080i. However, HDMI is capable of 1080p. DVI definitively can transmitt interlaced signal such as 1080i.
Nic Rhodes
DVD is 8 bit and I think this is all we are using at the moment with HDMI. The rest is for the future.
The point I am making is it isn’t as simple as plugging HDMI outputs into DVI D inputs (ignoring HDCP). DVI D inputs are VERY restricted in comparison to their HDMI cousins. Also there are a few oddball (R2) issues that still need to be ‘ironed’ out BUT this should be being done in the compatibility testing labs. The only way to find out is to try.
As I understand it at the moment conventional RGB inputs analyse all signals and lock onto what it detects. DVI D inputs are programmed to specific ‘computer’ based resolutions and many older DVI inputs don’t analyse per se but try and lock to a specific set of computer based resolutions. The problem arises because all the DVD resolutions are NOT on that list (this is why it was possible to reprogram the Panny by changing a few numbers in the code).
This also ignores 480i/576I HDMI inputs issues, PAL ‘resolutions’ (can’t see them in the HDMI spec!!) and several other oddities. Pioneer HDMI output to Pioneer HDMI input works well, the problems arise when HDMI outputs are fed to DVI input in general hence my warning about them NOT being the same. It is easy to make mistakes here.
JohnWH
I beleive this is jmos, so firware upgrades could fix the issues with "supported" resolutions. Obviousley the companies selling the PJ's want you to upgrade so I suspect this isn't generally going happen.
John.
Matthew J Taylo
Just recieved this in my tray
http://www.cable-shop.co.uk/shop/customer/product.php?productid=182&cat=82&page=1
It looks as if you can purchase a HDMI to HDMI or a HDMI to DVI connectors from the Cable Shop, £179 sounds a bit steep, Techtronics are selling (well, if they had any that is!!) HDMI cables for 29 squids.
It;s all falling into place to purchase the Panny for my Pio 686avi-s
Matt
JohnWH
I'd be interrested to here what your results are like. I'm using the samsung 935 and seem to suffer the usual black level and green tint issues. However, having found that I get same problems with dvi fed from my PC when playing vid I'm now convinced this is just an issue with the PJ being setup for use with computers over DVI not video. I've just picked up the key sequnce to get into the service menu of my PJ so will try correcting the problem there.
Anyway will be interresting to here how smoothly it goes for you...
John.
Matthew J Taylo
John,
You may need to wait for a while, I've been talking about buying a plasma for the last year!!
I'm getting closer, the Pio 868AVi-s I recently purchased + the increased PQ of the latest pj's has spurred me on.
Would just like to know if it's worth buying the Panni PWD6 (HD plasma) & connecting it via a HDMI to DVI-D connection, how much of diff on PQ is this going to make Vs a HDMI to HDMI connection - if I can answer that, I'm a lot closer, £1,000 closer in fact!!
Will let you know how I get on
Cheer Matt
rscott4563
As long as the connection works, which it should, then there will be no difference in picture quality when comparing HDMI -> HDMI to HDMI -> DVI, as there is no conversion of the signal going on, i.e. its the same over a HDMI -> HDMI cable as it is over a HDMI -> DVI cable.
Ryan
Matthew J Taylo
Ryan,
Thanks mate, about the only one who's used the english language to explain things.
The TH42PWD6 Panny plasma is the cheapest, £2,474 @ IVOJO.CO.UK but it looks as if I'm going to have to buy quite a few terminal boards
1 - DVI terminal board for HDMI to DVI-D @ £146
2 - Scart board for Ps2 @ £146 (I could daisy this via my digibox)?
I assume the 15 pin, D sub terminal (already on the plasma) I can use for a JS tec RGB scart to VGA connector for my digital cable & Ps2 if daisied?
Not sure if you know all this, if not hopefully someone following this thread will be able to answer me questions.
Whlist I'm at it, JS tech's also make a scart RGB to composite converter, is this better than the rgb scart to vga convertor?
matt
rscott4563
I'd certainly recommend Ivojo, I've got my 50" Panny on order from them, great service from Ken.
Not to sure of which is better RGB2VGA or RGB2Component (I assume you mean component not composite :thumbsdow ) but you should be able to daisy chain and then just use one converter (VGA) and input straight to the PC HD15 input on the plasma, definitely better than the scart option and cheaper to boot.
Ryan
Matthew J Taylo
Thanks Ryan,
You wouldn't happen to know which terminal board I would need to have installed for a HDMI to DVI-D connection?
I've got the manual infront of me & ti doesn't make alot of sense. I'm sure I need a terminal that will allow for a 1125(1080)/60i signal? (is this the best resolution?, ie 1080 lines?
The RGB terminal boad, TY-42TM6D (DigitalW/HDCP) looks like the fella but I'm not too sure if this will give the best quality picture Vs the PC Input, TY-42TM6P/G ?
Nexnix do quote the TM6D as the RGB DVI Digital Terminal Board
I'm a bit lost here? - Panny pdf below
Matt
http://www.nexnix.co.uk/pds/docs/Panasonic Plasma 6.pdf[/URL]
rscott4563
The TY-42TM6D is the only DVI card available and the only way to feed the plasma a digital signal from your DVD player, its RGB as thats the transport medium for DVI.
As to 1080i (1125i) this could be the best resolution but its not a definate, obviously you'll be able to try different combinations, 720p could be a better choice as that way the DVD player is doing the deinterlacing not the plasma, though it depends on how good the deinterlacing is in the player compared to the plasma.
Ryan
