Pioneer 868+Nec HT1000+HDMI-DVI Cable
Discussion in 'Projectors, Screens & Video Processors' started by misco007, Jan 5, 2004.
  1. misco007
    misco007
    Any experience with these elements?
    I´ve read that the Nec is DVI-D (HDCP) and the Pioneer is HDMI, but I would like to know if will be video compatible.
  2. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    it should be...... i cant think of why not though i guess someone might correct me on that (hopefully wont since this is a possible upgrade step for me)
    ad
  3. ailean
    ailean
    This should be okay with the correct adapter, at least according to the handy test tables on this french forum.
    DVI-HDMI tests
  4. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,479
    Surrey. UK.
    +2,123
    If you get it working, I'd be interested in the results. I was recently over at RTFMs, and he was running an 868 into the Sim2 iLINK, and the picture seemed a tad better than from htpc via DVI.
    RTFM was running it in pixel to pixel mode at 720 IIRC.
    Gary.
