Pioneer 868 multi-region hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by togad, Dec 5, 2003.
  1. togad
    togad
    Sep 14, 2002
    291
    +3
    My player wasn't multi-regioned by the dealer (they were waiting for details from their Pioneer rep).
    So, I did it myself :)
    You need the following IR code in a multi-remote:
    0000 0069 0049 0000 0154 00AA 001E 0032 0019 003C 001E 000F 0019 000F 001E 000A 001E 0037 0014 0005 0005 000A 001E 0037 001E 000A 001E 000F 0014 003C 001E 0037 001E 0037 0014 0014 001E 0037 0014 0014 001E 0037 001E 000A 001E 000A 001E 0037 001E 0037 001E 000A 001E 000A 0019 003C 001E 000F 0014 003C 001E 0037 001E 000A 001E 000F 0014 0005 0005 0032 001E 0037 001E 000A 001E 045B 0154 00AA 001E 0032 001E 0037 001E 0037 001E 0037 0019 000F 001E 0037 0014 0014 001E 0037 0014 0014 001E 000A 001E 000F 0019 000F 001E 0037 0019 000F 001E 0037 0019 000F 001E 0037 0014 0014 001E 0037 001E 0032 001E 000F 001E 0032 001E 000F 0014 0005 0005 0037 0019 000F 001E 0037 0019 000F 0014 0005 0005 000A 001E 0037 001E 000A 001E 0037 001E 0037 0014 0465 014F 0000
    Seems to work fine!
  2. alquimista
    alquimista
    Hello:
    I am trying to convert the codes you have posted to hack the Pioneer 868 to hexa in order to use my HP 48G calculator and the remote control program posted at http://www.rhoads.nu/bjorn/hp48/index.html .
    The conversion should be easy following the instructions explained at http://www.geocities.com/SiliconValley/Lakes/3947/ccf.htm . But unfortunately your codes are quite difficult to understand.
    Would you mind explaining which sequence of codes is an '1' and which one is a '0'?
    I have seen another hack at http://www.videohelp.com/dvdhacks.php?dvdplayer=Pioneer+868 and the translation is the following:
    Header:
    #C53A0000h
    #C53A0067h
    #C53A0000h
    #C53A0044h
    Sync:
    #C53A0155h
    #C53A00ACh
    #C53A0015h
    32 bits: C53A9966
    End:
    #C53A0404h
    Sync:
    #C53A0155h
    #C53A00ACh
    #C53A0015h
    32 bits: F50AB54B
    End:
    #C53A0404h
    Unfortunately, I can't make it work. What I need is each 32 bit string in your code. :lease:
    Thank you very much.
