Pioneer 839 receiver or not?
Discussion in 'AV Receivers & Amplifiers' started by msabic, Mar 8, 2001.
Tags:
  1. msabic
    msabic
    I called to try to find out if this receiver would work with the Celestion C series speakers and a technical (so he says) guy from Pioneer NL told me that this 100 Watt receiver couldn't drive them because they are rated at 4 OHM and sometimes drops to 2. He says that the receiver will be damaged.
    Should I just look for different speakers or what reasonably priced 100 Watt Receiver would you recommend.
  2. msabic
    msabic
    For those interested in Celestion C series speakers, I actually called Celestion and they told me that the Denon 3801 was much better with their speakers.
    Ciao,
    Miro.
  3. msabic
    msabic
    Ciao,
    Miro.
