Pioneer 812 not picking up DD
Discussion in 'AV Receivers & Amplifiers' started by common, Dec 16, 2003.
Tags:
  1. common
    common
    Mar 5, 2001
    1,397
    41
    Oxford UK
    +8
    Need to go home and have a good play, but when testing my new Pioneer 812 last night I couldn't get DVD's to play in Dolby Digital.
    DTS from DVD - fine
    Dolby Digital from Xbox - fine
    Dolby Digital from DVD - goes to Prologic II ?
    Any ideas
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,439
    United Kingdom
    +1,820
    Have you missed a setting in the DVD player for Dolby Digital? It should be set to Bitstream.
    Other things I can think of:
    Have you selected the Dolby track on the DVD itself? Is the amp set to AUTO?
    Is it connected via analogue leads as well? Maybe it's picking that signal up instead.
  3. Arsenal
    Arsenal
    Mar 25, 2002
    232
    London
    well the xbox test would seem to rule out the amp and disc from being the problem.. I would look at settings on the dvd player.. though it does seem strange that dts would be enabled but not dd.
  4. common
    common
    Mar 5, 2001
    1,397
    41
    Oxford UK
    +8
    I've been out of AV too long !
    I remember the player having a setting of PCM for DD - I will change to bitstream
  5. Mark123
    Mark123
    Sep 20, 2003
    454
    Belfast
    +29
    when the DD dvd is playing, try pressing the 'standard' button on the remote. This should 'force' DD on the amp if a DD signal is being received.
  6. Malky1903
    Malky1903
    Jul 2, 2003
    1,937
    48
    Aberdeen
    +64
    If all of the above fails, when playing a DVD, push the signal select button located behind the pull down flap.
