Pioneer 757 vs Denon 2800 II
Discussion in 'Blu-ray & DVD Players & Recorders' started by kn2468, Feb 10, 2003.
  1. kn2468
    kn2468
    I see plenty threads on the Denon 2800 II. Mostly to do with chroma-bug and freezing. Very little is discussed on the 757. Is this a good player when compared against the Denon 2800? Also is the lack of threads a sign of more satisfied customers?
    Also has anyone seen how it compares to the 3800 Denon.
    The Pio gives the playback of SACD and DVD-A in addition to the usual.
  2. mutley
    mutley
    Jul 28, 2002
    450
    Portugal
    have one, beats the 2800.... KO!!!!!
    It's simply perfect.... for the price. At the time i put my eyes on the 757, 2800, 3800, dv88+.
    3800 was slightly better on picture but not noticeable if not on a plasma or projector. (not my case - RP)
    The difference is minimalist so 757 was my pick. What a pick!!!!
    No freezing, no problems at all.... (one of the problems of the 3800, 2800); better than the arcam (IMHO)
    Just Great.
  3. kn2468
    kn2468
    Thanks for that reply. I was begining to think the 757 did not deserve to be on the list. Since I mostly will purchase R1 dvds, the NTSC progscan only is not an issue.
    Good to see you rate it that well. Thanks.
  4. Costas
    Costas
    Jan 14, 2003
    1,663
    63
    Swindon, UK
    +120
    Do a search on 757 on this forum.. you will find just a little bit.
    From my side, I have done many tests (see other threads) and I am totally happy that this is classy machine desrving every credit.
    Feel free to ask more after you check...
  5. crispeb
    crispeb
    Feb 10, 2003
    122
    Leicester
    I'm now the proud owner of a 757 having just successfully returned a 2800 MK1 for a refund. Sure the 2800, whether MK1 or MK2, is an awesome piece of kit on paper but I lost patience with it's completely erratic performance. If you enjoy picture freezing and sound drop out by all means invest your money but I'm overjoyed that I've sent mine back to the Denon scrapheap. Buy a 757 for peace of mind - it may cost a few pounds more but with sound and picture quality the equal of the Denon and reliability built in as standard it's a no brainer!
  6. vee_cee
    vee_cee
    I'll add myself to the list of satisfied 757 owners.
    I was also looking at the 2800mkII and DV88+, but the numerous problems put me off, and regular firmware updates.
    6 weeks old now no probs with any discs and even does a decent job of spining normal cd's
    VC
  7. kn2468
    kn2468
    Thanks - you have made up my mind.
    Pioneer 757 it is.
    Nice to see such good feedback.
