Pioneer 757 hi-bit and legato pro
Discussion in 'Blu-ray & DVD Players & Recorders' started by juboy, Apr 10, 2003.
  1. juboy
    juboy
    Just got my new player and wondered whether those who've had the 757ai a bit longer have any thoughts on the Legato Pro setting? I have it set to 'off' at the moment, anyone found it better on a particular setting?
    Also, as the Pioneer 2011 amp does hi-bit upsampling, what happens if you use the DVD player's hi-bit function AND the one on the amp... or can you even do that?
    Any experiences or suggestions appreciated.
  2. Costas
    Costas
    Jan 14, 2003
    1,663
    63
    Swindon, UK
    +120
    In my opinion, it is extremely hard to feel the difference using Legato PRO. I keep it "Off". This filter affects mostly frequencies outside the audible range and it very much depends on the listening conditions. On the other hand I keep Hi-Bit "On". It does bring more detail of low-level sounds helping particularly when you play DVD at relatively low volume. I do not have the Pio amp and I cannot judge the Hi-Bit further. However I think the function will perform better if you do it through the player.
