pioneer 737
Discussion in 'Blu-ray & DVD Players & Recorders' started by keyser, Jun 3, 2002.
  1. keyser
    keyser
    Jul 23, 2000
    903
    gardabaer, Iceland
    Does the pioneer 737 send out both pal and ntsc signals through the component, both in progressive scan? If not, would I then have to connect my dvd differently for pal and ntsc movies?
  2. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,373
    Norwich
    +895
    the 737 sends out pal and ntsc through the componenet, however it only sends an interlaced signal with pal discs.
    but you dont have to swap connections and you can leave the setting for progressive and the pal interlaced signal is fine.
  3. keyser
    keyser
    Jul 23, 2000
    903
    gardabaer, Iceland
    Brilliant, thanks.
