pioneer 737 swap for cambridge audio azur?
Discussion in 'Blu-ray & DVD Players & Recorders' started by dexter, May 20, 2004.
  1. dexter
    dexter
    Jan 27, 2002
    214
    I have a Pioneer 737 - it is a fine player but I really want PAL progressive scan and DVD Audio - neither of which the 737 has. I can get £200 for the Pioneer and am on a limited budget. I can add a further £100 to the £200 and the Cambridge Audio fits in my price range and seems to offer what I want. Question is - will I notice a decrease in PQ/ SQ over the 4 year old Pioneer?
  2. roversd1
    roversd1
    Hi Dexter
    I have one of these and can only recommend it if like me, you're not impressed with mainstream offerings.
    The Cambridge on a small 28" TV has good blacks and good definition.
    For testing DVD players-
    Sound quality will nearly always depend on your processor, with picture quality depending on your display settings. Most TVs have a 'smart mode' which can make things worse. Disable all these type of modes.
    Set your display correctly first, then any DVD picture demos will be more accurate.
    My yardstick is a DVD32R which gives one of the best analog pictures available.
  3. dexter
    dexter
    Jan 27, 2002
    214
    Thanks for the reply - what would the Cambridge Audio Azur be like on a projector - 7ft screen?
