pioneer 737 progressive scan question
Discussion in 'Blu-ray & DVD Players & Recorders' started by todinks, Dec 12, 2001.
  1. todinks
    todinks
    hi, i have the pioneer dv-s737 dvd player
    the problem is that the progressive scan indicator on the front panel refuses to light up
    i have the sony vpl-vw11ht projector
    the indicator used to light earlier and all was ok....
    ................. but recently i switched from a prologic to a digital amplifier and had to ofcourse change the audio settings of the dvd player to "digital on"....thats when the progressive scan indicator went off although i've not fiddled with the video settings at all
    also, the progressive scan indicator is ON when u switch on the player but goes off the second u actually PLAY a dvd
    HELP!!!!!!!!
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,522
    Somewhere in South Yorkshire
    +5,996
    Don't know if this is it but......
    1) The progressive scan feature is disabled for any PAL (eg Region 2) disc therefore it won't light up with a PAL disc in the player.
    2) It won't light up at all, if you have the switch on the back of the player set to PAL. You need it set to "Auto".
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    PS (progressive scan) on DVD is currently available for NTSC discs only, no PAL progressive - sorry.
  4. todinks
    todinks
    thanks for all the info guys, i checked the dvd i had been playing n it was PAL!!
    i could hardly believe it myself as i thought all dvd's available here would necessarily be NTSC
    i'm grinning again
  5. johnson
    johnson
    May 12, 2001
    552
    Essex
    +6
    Unless of course you have a Denon 2800.
  6. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Unless you have a modified Denon 2800 I think ...
  7. LV426
    LV426
    Jul 14, 2000
    13,522
    +5,996
    Where is "here"?
  8. todinks
    todinks
    bombay, india
    majority of dvds available here are ntsc but i discovered that a few pals do float around much to my chagrin
    i owe u one dude
    allrightythen
