Pioneer 737 progressive problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by Simon Bown, Oct 20, 2001.
  1. Simon Bown
    Simon Bown
    Hello all
    I connected my 737 to my Barco 708 and when I switched to component progressive the colour of the picture had a heavy red saturation which then slowly went to a normal colour temp. This happens in a continuous cycle of approx 30 seconds. When the 737 is switched to plain component or composite I have no problem. This leads me to believe the problem is the dvd player and not the projector.
    Has anybody seen this before? Can you help me?
    Thanks in advance for your replies.
  2. Simon Bown
    Simon Bown
    Thanks for that I had not considered the macro thing. I'm going to have to call the shop on that one I didn't ask when I bought it.
  3. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    MV should not affect only one color and it's unlikely it causes trouble in PS mode only.
    MV usually will distort the entire picture and make it unwatchable, kind of pulsing or so.
    Yet I would assume it's a problem with the DVD player, perhaps with the PS function, so better get it (and the projector) checked out.
  4. John F
    John F
    Jul 13, 2000
    3,437
    83
    Newcastle
    +110
    is you dvd player macro disabled i think that is whats causing your problem.
