pioneer 737 or htpc ????
Discussion in 'Blu-ray & DVD Players & Recorders' started by jason t, May 19, 2001.
  1. jason t
    jason t
    Mar 4, 2001
    1,709
    48
    kent
    +38
    hi can you please advise me on which would be a better option, a pioneer 737 or a htpc?
    i will connect it to an lcd projector with proggressive input
    thanks
    jason
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,216
    +3,071
    Well, it depends....
    Some LCD units will not allow aspect ratio control when fed a rgb signal. With these you'd have to use the HTPC with aspect ratio control software such as YxY. This may make it harder for others to operate (which may be a bonus of course) ;)
    The 737 is plug and play but outputs in Component. You'll have to make sure the projector accepts prog component inputs. This is undoubtedly the easiest option but I'd think a well set up and designed HTPC may offer superior video fidelity.
    Gordon
  3. jason t
    jason t
    Mar 4, 2001
    1,709
    48
    kent
    +38
    hi gordon
    i will be using a sanyo plv30 if this helps
    jason
