Pioneer 717 RGB question?
D
Dan110
Is it only scart AV1 on the 717 dvd player that outputs RGB or does AV2 also output an rgb signal.
groundy
I used to own a 717 years ago and as far as I can remember, only AV1 outputs RGB, though AV2 may have an RGB pass-through facilty for interlinking other RGB equipped devices.
I used to own a 717 , it wont loop rgb through the second scart , i had mine modifed by video tec to achieve this, the second scart as on most videos and dvd's is only an input- nothing comes out of it.
Kevo
Do they have a web page?
How much did it cost?
Does the pass-thru still work when the DVD is turned off?
