Quantcast
Pioneer 668vs868 video performance through HDMI
G
ggp159
I was wondering if via HDMI this 2 players have the same video performance. Oh and i did search the forums and i haven't find a definitive answer. I want to know this because i have a 434 and i want to take advantage of the HDMI input given that my current dvd player is six years old!!!. Thanks
inzaman
I havent seen these two side by side but am probably planning on getting an 868 when i find one in stock locally, that will probably be 2005 then. The main selling point for me is the fact that i have a pj and the 868 can upscale to 720p and output this via hdmi where as the 668 cannot.
I am not that familier with plasmas but if your 434 is 720 native resolution then the 868 would be better.
alancolledge
ggp159,
Have you considered the Yamakawa through DVI? Mine works through a DVI to HDMI lead and the player upscales to 720p as well (does 1080i too)
I wouldn't like to talk about the different picture qualities as I haven't seen much of the 868 but I am duly impressed with this player as I have also recently upgraded from an old machine!
:hiya:
jdl
The difference is the 868 can give HDMI output up to 720p and 1080i, that means it has a more powerfull scaler inside because the 668 can give only 480p and 576p so the difference is quite big.
Go for the 868 hope i helped.
gandley
the 868i also passes an Interlaced signal via HDMI, which will be great for an pic improvment when external HDMI scalers/deinterlacers become available.
