Pioneer 656a & RCE
M
MalcT
Quick question before I order - can the 656 play RCE disks?
S
smallman28
I take it you are talking about a multi region machine,if so check with who you are getting it from but shouldn't be a problem.
Also best of luck trying to get one,I though they were hard to get with new stock not coming out now till January.
M
MalcT
Sorry, I meant order the DVDs - I already have a multi-region 656 (bought from Richer Sounds, £340).
That's a yes then?
wilber
Richer Sounds in Bristol have just got them back in stock at £330 multi-region. The Manager there told me that the group had secured 300 machines that they hoped would last 'til xmas but he doubted that they would last more than a week or two.
Just off to pick mine up:p :)
mancubas
When I last looked Empire Direct have some also, £307 inc VAT & Delivery you cannot knock the price, mine is being delivered on wed.
Prey + Bullet Train reviews, Heat 4K + Event Horizon 4K and all the latest movies and TV news
