phil_evans
Picked up one of these yesterday after problems with 3 successive Toshiba 220Es. Decided to move to a slightly higher price bracket to partner my Pioneer 433MXE plasma.
Cabled it up using a digital optical lead (to Yam RXV630) and Component (direct to Plasma). First impressions were good - solid build quality, easy and comprehensive setup function including a "wizard" to make the initial settings.
First disk played was R2 Hannibal and immediately my wife said "is that the DVD player?", referring to the drive mechanism noise. It did seem to quieten down as the player warmed up but it was noticeable initially.
Switching between S-Video and Component it was clear that component offers a noticeably better picture - an example is simply the Pioneer logo when you stop a disk - it bleeds a bit on S-Video (though its much better than composite), but is pin sharp on Component. OTOH the colour seems a bit washed out on Component in comparison to SVideo, but can of course be adjusted using normal TV/plasma settings.
Then it finally dawned on me - why all this PAL Progressive fuss? I started seeing "jaggies" on high-contrast horizontals (e.g. fence rails, telegraph wires and the tops of chairs in the lecture theatre - about 29 - 30 mins into Hannibal). Nightmare - spoiled the film for me. I don't remember the Tosh 220 having this problem but maybe it did. I tried some other disks and started noticing it on all of them.
So I'm disappointed but its my own fault for not doing more research/ testing. Plan B (C?) is to replace the 656A with a much cheaper DVD (as I don't really need DVD-Audio/SACD) and start saving/ waiting for some £300-500 PAL progressives to turn up. Here's hoping the Philips 963SA arrives soon and is hackable/upgradable to PAL Prog.
Anyway I think the moral of all this is - if you buy a high quality display device, budget for some expensive sources too. And don't even get me started on lip-sync... ask Party Animal about how expensive that one may turn out to be!
If anyone's got any questions about the 656A before I return it, fire away.
Phil
Phil
