pioneer 656 region hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by jonny boy, Jan 5, 2004.
  1. jonny boy
    jonny boy
    hi,
    have read the info about how to multi regionize the pioneer 868 and others but can any one explain to me if i can use my marantz 3200 remote and if i can how do i program it with all those codes!!!
    thankx in advance
    jonny boy:hiya:
  2. mseabroo
    mseabroo
    Aug 28, 2001
    376
    28
    Sussex
    +41
    Simple answer is yes you should be able to.
    I'm assuming of course that the 3200 is a pronto clone, like the rest of the Marantz range. Even if it is not, so long as you can input the hex code directly to a button on the remote it should work.
    The code is as follows.
    Put the player into standby, send the code & you should be done.
    May take a couple of attempts though.
    The hex code is as follows.
    0000 0067 0050 0000 0154 00af 0016 0040 0016 0040 0015 0015 0015 0015 0015 0015 0016 0040 0015 0015 0016 0040 0015 0015 0015 0015 0016 0040 0016 0040 0016 0040 0015 0015 0016 0040 0015 0015 0016 0040 0015 0015 0015 0015 0016 0040 0016 0040 0015 0015 0015 0015 0016 0040 0015 0015 0016 0040 0016 0040 0015 0015 0015 0015 0016 0040 0016 0040 0015 0015 0014 045d 0154 00ae 0016 0040 0016 0040 0016 0040 0016 0040 0015 0015 0016 0040 0015 0015 0016 0040 0015 0015 0015 0015 0015 0015 0015 0015 0016 0040 0015 0015 0016 0040 0015 0015 0016 0040 0015 0015 0016 0040 0016 0040 0015 0015 0016 0040 0015 0015 0016 0040 0015 0015 0016 0040 0015 0015 0015 0015 0016 0040 0015 0015 0016 0040 0016 0040 0014 045d 0154 00ae 0016 0040 0016 0040 0015 0015 0015 0015 0015 0015 0016 0040 0015 0015 0016 0040 0015 0015 0015 0015 0014 00af
  3. jonny boy
    jonny boy
    thanx very much for your help
  4. Irish1
    Irish1
    Feb 13, 2003
    35
    Carlow Ireland
    I have a Marantz SR6200 and I want to use the region hack on Pioneer 656A how do I enter the code onto the remote??
  5. jonny boy
    jonny boy
    sorry I could not get the hack to work!
