Pioneer 656 or Philips 963 or HKDVD25??
Discussion in 'Blu-ray & DVD Players & Recorders' started by Mogli, Apr 11, 2003.
  1. Mogli
    Mogli
    Feb 25, 2003
    764
    43
    +124
    I am lost defeated and confused now... i thought i wanted a 656 and then i saw the 963 and now i have seen the hk 25 is also highly rated.
    I dont have a progressive tv at the moment but i would like to be future proof to a certain extent.
    Which of the above players provided the best rgb picture? Which is sonically the best?
    Its too hard.. i would like to stretch to the 757 but not having a progressive tv (and seeing other upgrades as being more important really) i dont think its worth the extra expense (tis an amazing player though :) ).
    Any help you can give would be greatly appreciated :smashin:
  2. Costas
    Costas
    Jan 14, 2003
    1,662
    63
    Swindon, UK
    +121
    Mogli,
    Research this forum against these models carefully and in my opinion at least, go fro the 656 (or the 757 if you can afford)
  3. sounddog
    sounddog
    Dec 11, 2002
    3,370
    107
    Leicestershire, UK
    +461
    The 757 is great even on a non-progressive CRT display.
    Yes the Philips and HK have PAL progressive scan ... but as you say you're TV isn't progressive scan.
    The Pioneer on the other hand will play any and all disks (SACD as well as DVD-A) so in that sence its more future proof than either.
    I've not compared the three players you meantioned so can't give a idea of which is best on RGB.
    Vikki
  4. Dutch
    Dutch
    Dec 5, 2002
    2,580
    3
    North Yorkshire
    +263
    Hi Vikki,
    I'm pleased to hear that you're happy with your new 757 - I think it's a superb machine. :smoke: How about changing that sig now? :p
    Steve
  5. Klippie
    Klippie
    Dec 1, 2002
    627
    Scotland
    +58
    Mogli,
    I went though all this dvd stuff a while back and decided on the Philips 963, it has issues do a search and you will find them but with a bit of tweaking here and there it can be set up to look fantastic. I have read that it outputs a very good interlaced picture but I cannot verify this as I use it Pal prog for my projector.
    As for the sound department it sound very good indeed, I even use it as my cd player now as well.
    Hope this helps.
    Klippie.
  6. Mogli
    Mogli
    Feb 25, 2003
    764
    43
    +124
    Thanks for your help everyone tis much appreciated :).
