Pioneer 656 / CD Audio any good ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by iwatkins, Dec 20, 2002.
  1. iwatkins
    iwatkins
    Hi All,
    Looking to by a 656. By all accounts it is a cracking machine for DVD-Videos. I'm also interested in DVD-Audio and SACD hence this machine.
    However, does anybody have comments on whether the sound from a standard Audio CD is any good ?
    I know that a dedicated CD Player would be the way to go if it was that important, but I have room/missus constraints.
    Thanks for any comments.
    Ian
  2. pentode
    pentode
    Dec 17, 2002
    109
    West London, UK
    +4
    I have a DV656A, a Sony multi-changer & a NAD 541i all connected on digital links to my amp. The CD stereo audio quality of the DV656A is acceptable, but only average. The Sony is better and, of course, the NAD is best !
    Don't let this put you off, though. The SACD & DVD-A modes (using the analogue outputs) are stunning, as is the video.
  3. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,688
    UK
    +116
    Normally, to get good video AND good CD, you need to spend a little more...in the region of the Arcam DV88/DV88+ or Denon 3800 to get the best of both worlds...
    All IMHO of course...
    JJ
  4. siluro
    siluro
    Jun 11, 2002
    443
    The Original "Garden City"
    At the min im running the 656 in to a arcam avr200 by the analogue ouput and ok so it maybe not the best solution but CD play back for the price is amazing, certainly no slouch plus the video is pretty hot to boot.
    For £300/350 asking price you really carnt go wrong
    cheers
    lee
  5. iwatkins
    iwatkins
    Thanks chaps :)
  6. alexs2
    alexs2
    Nov 13, 2002
    13,961
    +1,671
    Excellent player,which loses little in terms of video or audio quality to things costing significantly more.
    Only thing you could possibly comment on is that the DVD 757i also comes equipped with a Firewire link for transmission of encrypted digital data(assuming you have processor capable of accepting it!...currently the only likely candidates are Denon,Pioneer and Tag with the AV192).
  7. warrj
    warrj
    alexs2 - Will they be 'standard' (e.g. could one plug a Denon DVD player into a Pioneer amp) or will each manufacturer develop their own digital interface for high-res audio?
    Regards,
    Jules.
  8. paiger
    paiger
    The 757 uses iLink (Firewire) which is an industry standard connection and just coming in for AV. The only amp currently on the horizon with an iLnk input is the Pioneer AX10i. If more amps get this feature then the 757 should work with them.
    Denon and Tag use their own proprietry link which I think is based on an RJ45 plug and as far as I am aware is not compatible with other brands. They are certainly not Firewire.
    Steve
  9. warrj
    warrj
    Even if they all use Firewire it doesn't necessarily follow that the software interfaces will be the same. Unless of course a standard has been agreed. Anyone know if this is the case?
    Regards,
    Jules
  10. paiger
    paiger
    I think this is the intention although a much better solution is HDMI which can carry high res audio and video in one lead, like a high res digital scart. This is being developed right now and I guess will filter in during the next 2 years.
    S
