pioneer 6090 universal bracket
Discussion in 'Home Cinema Buying & Building' started by kellyleekyle, Feb 12, 2009.
  1. kellyleekyle
    kellyleekyle
    Oct 26, 2007
    202
    chorley, lancs
    +13
    can anyone suggest a universal bracket to fit the pio 6090. all the ones ive seen, even the ones on amazon listed for this tv have max fixing of 800mm, but this panel is 85cm so none will fit, i cant fit a pioneer bracket in the floating wall ive have,
    thanks
  2. Member252055
    Member252055
    Jan 23, 2008
    1,850
    83
    Nottingham
    +290
