pioneer 606d
Discussion in 'Blu-ray & DVD Players & Recorders' started by MiG, Jan 28, 2002.
  1. MiG
    MiG
    hi, anyone out there own a pioneer 606d, if so u might be able to
    help out, had the player for 4 yrs crackin machine (at the time) recently got a new 36 tosh so thought of going straight to the tv (as it is DD) and bypassin my old pro-logic amp .connected pioneer to tv using component and optical out, but whenever i switch the output to 5.1 there is nothing, also does this machine play v'cds ????? cos mine just spits them out
    any help and U will be gods
  2. DaveP
    DaveP
    I've got one of these but it's ages since I went into the menu system or changed anything but it may be you have to specify in the setup to use the optical link.
    Is the Video CD one you created? The 606 won't read CD-R or CD-RW disks.
    DaveP
  3. lmccauley
    lmccauley
    Oct 24, 2000
    3,469
    Newcastle
    +291
    I went from using the 6 channel outputs to digital output on my 606 a couple of years ago, and I'm afraid I can't remember what settings you have to change :rolleyes: . I would check for you when I got home, but I've just boxed up my 606 after replacing it with a 545. It does work, though, and you should notice an improvement (the decoder of the 606 is lacking in several ways).
    Cheers,
    Liam
  4. dj
    dj
    Apr 4, 2001
    257
    Milton Keynes
    +17
    Check the setting of the DIG Output on the Output menu.
    Not tried any VCD in the player, but it reads auto CD-R and CD-RW disks without problems.
