pioneer 575A
Discussion in 'Blu-ray & DVD Players & Recorders' started by beavis2ooo, Mar 28, 2005.
  1. beavis2ooo
    beavis2ooo
    HI, had dvd player for couple of weeks now. what i notice about player, is the amount of time it takes start up/ load dvds. is it normal to take what seems minutes?.
  2. IBORGUK
    IBORGUK
    Mar 27, 2005
    246
    London
    +9
    That length of load time seems excessive to me, assuming of course it really is minutes. I've had mine for 2 months. Only complaint I've had is he noisy drive noise on the chapter search.
  3. beavis2ooo
    beavis2ooo
    Its actually a long few seconds. It may be normal, but compared to my old tosh which was straight away.
  4. IBORGUK
    IBORGUK
    Mar 27, 2005
    246
    London
    +9
    Then that sounds normal.
  5. beavis2ooo
    beavis2ooo
    just thought id ask, Thankyou.
  6. FaB*Bo*Peep
    FaB*Bo*Peep
    This is one of the things I immediately noticed about my new 575 compared to previous players so you are not alone, it definitely takes longer than anything else I have used.
  7. NX3
    NX3
    Dec 4, 2002
    3,488
    103
    +332
    Per the other threads on the 575 have got you the latest firmware and if not I'd suggest updating to the latest. Use the search facilty and you will find all the info you need, posted many many times :)
  8. mattross
    mattross
    Oct 23, 2004
    257
    +6
    I imagine longer load times are mainly because this is a universal player. I'm sure there must be overhead to detecting what type of disc is in, be it CD, DVD, SACD.
  9. Dillz
    Dillz
    Feb 25, 2004
    236
    Gloucestershire
    +8
    Yeah but why does the thing have to take so long just for the display to come on and say "No Disc".
    Sometimes I think I haven't pressed the power button properly, press it again, only to have it briefly come on then go off again. :rolleyes:
  10. NX3
    NX3
    Dec 4, 2002
    3,488
    103
    +332
    As per the other thread people have found it improves the loading times by updating to the latest firmware. I can only suggest again you use search and find the thread. The update is from, you can download it from avland.co.uk or request a cd from Pioneer.
    Can you tell us what version firmware you have ?
  11. Chrper
    Chrper
    Feb 10, 2005
    90
    I noticed the same load delay as you, I am at firmware version 2.04 and yesterday downloaded veriosn 2.09 whic is supposed to ( amonsgt other things) improve load up time.
    i plan to do it over the weekend, will post an update when I have done the upgrade, specifically in relation to load up times.
    Chris
  12. weavib
    weavib
    i have this dvd pioneer - my loading time is not quick but i can live with it- obviously would like quicker. how do you check the firmware version on the player? what else does a the newest version do to the player, as i am reasonbly happy?
  13. Chrper
    Chrper
    Feb 10, 2005
    90
  14. NX3
    NX3
    Dec 4, 2002
    3,488
    103
    +332
    As per the other thread quite a few people have done the update and no problems. Just hope its improves loading times for you.
