Pioneer 575a Sound but no Picture??
Discussion in 'Blu-ray & DVD Players & Recorders' started by micol, Jan 18, 2005.
  1. micol
    micol
    Oct 5, 2004
    241
    In front of my PC
    Hi!
    I've just bought the Pioneer DVD575a and i'm having difficulty playing a couple of avi files (XviD). The sound plays fine but the picture does not appear.
    Anyone else had this problem??
  2. NX3
    NX3
    Dec 4, 2002
    3,492
    103
    +8
    nope... I guess something is wrong with the encoding. Try re-encoding them as divx 5 see if they work.
  3. micol
    micol
    Oct 5, 2004
    241
    In front of my PC
    Thanks for your reply NX3. Is there a good guide for reincoding that you know of? They both have AC3 audio that I really want to keep, but some of the gudes/progs I have seen loose the AC3.
  4. NX3
    NX3
    Dec 4, 2002
    3,492
    103
    +8
    I dont know of any web guides but its fairly straight forward not to re-encode the audio.
  5. micol
    micol
    Oct 5, 2004
    241
    In front of my PC
    Could you tell me how?
  6. rickardl
    rickardl
    Sep 9, 2004
    744
    46
    Stockholm
    +127
    Yes, with avis with a resolution greater than 720x480(NTSC)
    or 720x576(PAL). You would need a 'Divx HD' player for that.
  7. micol
    micol
    Oct 5, 2004
    241
    In front of my PC
    that makes sense for one of my avi's as the screen size is 960x528. But what about this one:
    Total Streams: 2
    Running Time: 2:12:38
    Index Chunk: Yes
    Interleaved: Yes
    Max Bytes Per Sec: 0
    AUDIO: 0 - AC3 (0x2000)
    Average Bitrate Per Sec: 448 kb/s
    Samples Rate: 48000 Hz
    Channels: 5
    Bits Per Sample: 0
    SuggestedBufferSize: 28000
    Sample Size: 1
    VIDEO: XVID
    B-VOP: Yes
    S(GMC)-VOP: No
    QuarterPixel: No
    Frame Size: 640 x 256
    Frames Rate: 25.000
    Color Depth: 24
    Total Frames: 198957
    SuggestedBufferSize: 149922
  8. saibot
    saibot
    Jun 28, 2004
    1,240
    Near the Lee - Ireland
    +42
    Just had a similar issue with an avi thats 960x528, capture from a HD source. Did you ever get any procedure to make it fit the Pio ??
    d...
  9. micol
    micol
    Oct 5, 2004
    241
    In front of my PC
    Can't quite remember what I dod in the end. I think I used Dr.Divx. It dosen't do AC3 audio though. You can split the audio out with virtual Dub and then join it back after though.
    Sorry I can't be any more help!
  10. Prayer
    Prayer
    May 12, 2005
    10
    Tallinn
