pioneer 575a firmware help
Discussion in 'Blu-ray & DVD Players & Recorders' started by EvilEd, Mar 2, 2005.
  1. EvilEd
    EvilEd
    Mar 2, 2005
    45
    can anyone point me in the right direction for the firmware update for the pioneer 575a ..i have tried the Avland sit but teh download from there keeps coming up corrupt ..can anyone send it to me unzipped maybe ...thanks
  2. Lostinapc
    Lostinapc
    you can get pioneer to send it to you on a disc, how is on their website somewhere. Took me about a week to get it. There's a topic somewhere with the link, i downloaded it from here not long ago
  3. Ian C.
    Ian C.
    Jul 8, 2004
    720
    28
    West Midlands
    +45
    EvilEd you can get update from
    Pioneer.co.uk(support),customer
    support 01753-789-500 free of
    charge software update disc :thumbsup:SNAP!
  4. NX3
    NX3
    Dec 4, 2002
    3,493
    103
    +8
    The file on avland isnt corrupt fyi. I'd suspect something wrong your end with your pc. Run a virus checker, spyware remover (adaware)...are you on dialup or broadband ?
  5. EvilEd
    EvilEd
    Mar 2, 2005
    45
    Broadband it may be my version of winrar...i dont know think i will send off for the disc thanks for all the replies
  6. deanym
    deanym
    May 29, 2004
    1,833
    +143
    the avland file is a Nero native file which can only be copied to cd via nero. The firmware file is contained within the nero file. Open the downloaded file into nero then write this to the disc. The firware should then install.
    A demo version of nero can be downloaded which will suffice.
    Best of luck.
