pioneer 575 v 757i
Discussion in 'Blu-ray & DVD Players & Recorders' started by philthyanimal, Aug 18, 2004.
  1. philthyanimal
    philthyanimal
    I own a 757 and i am pretty pleased with it. But after reading a few posts i am starting to wonder if the 575 is a better player.
    should i sell my 757i and buy a 575 or keep the 757.
    I'm using a 32" philips flat screen tv.
    Does the 575 only have one scart, opposed to the 757's 2?
  2. inzaman
    inzaman
    Dec 16, 2002
    7,964
    Derby
    +1,029
    Do you connect the TV via scart or component, if component does it accept both PAL & NTSC progressive, and does your 757 output both PAL & NTSC progressive.
  3. philthyanimal
    philthyanimal
    i connect my dvd via scart(rgb) to the tv and pass my sky+ through the 2nd scart on the 757.
  4. Shockabuku
    Shockabuku
    Mar 5, 2002
    1,804
    Oxfordshire
    +163
    575 only has one scart...so no passthrough I'm afraid.
  5. inzaman
    inzaman
    Dec 16, 2002
    7,964
    Derby
    +1,029
    If you are just using scart then i would stick with the 757i, and as Shokabuku has said the 575 only has one scart anyway.
  6. pantages
    pantages
    Jan 7, 2004
    945
    2
    Boston
    +60
    Definitely the 757i! I was torn between the two until I compared their specs which decided me to go for the 757. No regrets either.
