Pioneer 575 stops in the middle of a Divx file
Discussion in 'Blu-ray & DVD Players & Recorders' started by harmony, Apr 19, 2005.
  1. harmony
    harmony
    I'm getting this problem while watching Divx files where the player stops playing and goes back to the menu. I need to replay the file and then forward back to where it stopped. The player usually stops again but this time at another place..
    Anyone seen this problem or know how I can fix it?
  2. NX3
    NX3
    Dec 4, 2002
    3,492
    103
    +8
    Update the firmware on your 575 to the latest version (search this forum I've posted the info loads of times). I would suggest its a bad encoding, its happened to me once on a less than perfect encoding. You could re-encode it...
  3. harmony
    harmony
    I am using the latest FW.
    Also the files play on other players using the SIGMA CHIPSET.
  4. NX3
    NX3
    Dec 4, 2002
    3,492
    103
    +8
    Maybe the Sigma is just better at error handling....or you have a duff unit.
  5. harmony
    harmony
    NX3 - yes, maybe, maybe, maybe, hence the reason I am asking to determine whether or not this is a known issue / common problem with other users.
  6. NX3
    NX3
    Dec 4, 2002
    3,492
    103
    +8
    I don't have this problem with divx / xvid on the Pioneer. I've not seen any other postings on here of that problem either. Hence I suggest to update firmware as some early versions caused various problems (see previous postings on here). Or you do a conclusive test by re-encoding the movie and checking if its a encoding issue* or a unit issue.
    *I'm assuming its something you download and thus could easily have a few corrupt bytes which when played on a PC it ignores and on Sigma based players.
  7. rickardl
    rickardl
    Sep 9, 2004
    744
    46
    Stockholm
    +127
    How big is the DivX file? I think there could be potential problems when
    they are bigger than 1 GB but that is only a guess.
