Pioneer 575 - Some DVDs start film instead of menu?
Discussion in 'Blu-ray & DVD Players & Recorders' started by robo989, Jun 22, 2005.
  1. robo989
    robo989
    Feb 14, 2004
    2,638
    68
    Carmarthen
    +70
    Just recently got meself a pioneer 575 and gotta say its superb, I've always bought real cheappy players before and the upgrade to this especially on the fruityness and contrast of picture is excellent, my extremely cheap daewoo 3210E tv has terrible contrast so it helps out abit...
    Anyway onto the problem...
    *some* DVDs act quite strangly...
    In a normal situation, you put the dvd in the player, disc spins up, main menu comes up on the screen...
    But, some of my dvds although they have a main menu (press menu on the remote when the dvd is playing and it comes up)...instead it jumps straight to the main movie as if you've pressed "play" in the main menu...
    I know its not a "fault" as such, its happened on a couple of other players but normally only with older titles that have been transferred to dvd...
    Like...Scarface (not the special\annivesery edition) its got a very basic menu but it never appears unless you specifically press menu on the remote when its playing...
    This behaviour occurs on....
    Tomb Raider - the cradle of life R2
    Kevin and perry go large
    and more just those are the 2 I remember that defo do, a few more outta my collection do as well though...
    Just curious if this is "normal" and can put my mind at rest really...
    Thank you for your input and help, Rob
    p.s it doesn't *always* jump to the film on these dvds, like 80% the time it will, if I set the dvd to not load discs automatically in the dvd player setup then it doesn't usually happen...
    I tried out tomb raider cradle of life on my old yamada 6600 and on that it works normally so its a bit confusing, the disc is fine and has no scratches\smudges whatsoever...
  2. sy278
    sy278
    Jul 4, 2004
    509
    28
    Glasgow
    +40
    I have a number of discs that do this on my pio 515, and they are all discs with very basic menus.
  3. nwgarratt
    nwgarratt
    May 5, 2002
    27,038
    +2,980
    Some DVD's start at the film even if there is a menu. Also, the player might remember the disc being played before and start where it left off.
  4. PJTX100
    PJTX100
    Dec 21, 2004
    8,134
    +564
    I've noticed this happening on some discs with all the DVD players I've owned, simply assumed it was the way the disc was "put together" - interesting that different DVD players may handle the same disc differently in this respect.
    A simple prod on the menu key if required sorts it out so I've never really given it much thought...PJ :)
  5. robo989
    robo989
    Feb 14, 2004
    2,638
    68
    Carmarthen
    +70
    Cheers,
    Nah, its not a problem as such just was curious as to weather everyone else experiences this or not...
    Just strange that the other player I currently have doesn't do this...
    and the fact that it doesn't happen all the time and the disc is spotless...
    Anyone else have anything to add on this?
    thanks for your time everyone :)
    Rob
