pioneer 575 playback problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by meath man, Mar 1, 2005.
  1. meath man
    meath man
    Jan 12, 2005
    598
    meath
    +7
    Hi , i just received a pioneer 575 dvd player from richer sounds belfast.
    When i put in some of the dvd copies i have it plays back the dvd but its in black and white- im not sure what format they were copied in cause it dosnt say it on the disc. CAn i solve this problem?
  2. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,383
    Bristol
    +10,095
    If they are playing in black and white it means they are NTSC encoded and your TV cant handle an NTSC60hz signal.
    How have you got it setup because as long as you are using a scart cable connected to the RGB enabled scart socket on your TV it should be playing in colour or you could set the player to PAL playback mode, this will force all discs to output as PAL50hz which will make NTSC DVDs playback in colour but there will be a slight stutter.
  3. NX3
    NX3
    Dec 4, 2002
    3,493
    103
    +8
    Are you using a RGB wired scart cable ?
  4. meath man
    meath man
    Jan 12, 2005
    598
    meath
    +7
    I have an old 4:3 tv and i am waiting until i cant find a decent widescreen tv in my budged.. how do you set the pioneer player to playback pal as indiana jones said?
  5. rickardl
    rickardl
    Sep 9, 2004
    744
    46
    Stockholm
    +127
    In powered down mode, hold in "next chapter"-button on the front panel and then press
    the power button. Each time this is done, it will shift from
    "Auto"->"NTSC"
    "NTSC" -> "PAL"
    "PAL" -> "Auto"
    (or similar order)
