Pioneer 575 or Samsung 945 or Yamaha S550?
Discussion in 'Blu-ray & DVD Players & Recorders' started by origbow1, Mar 8, 2005.
  1. origbow1
    origbow1
    Looking at upgrading my DVD machine (currently utilising my PS2) to either the Pioneer 575, or a Samsung 945 or a Yamaha S550. What's your thoughts on which is best? I have a lovely Philips 36PW9525 which I plan to replace with a plasma later in the year (Panny or Pioneer). Therefore, in the short term my DVD will be run through a Thor scart, until I upgrade to my plasma.
    I've read great things about the Pioneer 575, but will it play DVD+R/RW ok? I can get both the Pio and the Yamaha for £99 in silver, but my local Euronics has the Samsung 945 for £169 (Region 2). This has some future proofing with the HDMI socket, but some people have had playback issues with this machine? Am I better to go for the Pio or Yamaha now and upgrade to a better machine with HDMI in a year's time?
    Also, any news on whether Pioneer's replacement for the 575 will have HDMI and when it is likely due onto the market?
  2. Philly112
    Philly112
    Oct 17, 2003
    4,472
    Frodsham
    +1,886
    Can only answer one of your questions - the one about the Pioneer playing DVD +R and +RW.
    Yes it does!!
    Phil
  3. origbow1
    origbow1
    Hi Phil,
    Thanks for confirming that the Pio 575 does play +R/RW as it was a bit vague on the Pioneer website! That's good news as I would tend to use +R/RW more than the -R/RW format
    Anyone have any thoughts on which model is best for my setup? I have now also found the Yamaha S550 a little cheaper at £89. Decissions, decissions....
    Peter
  4. origbow1
    origbow1
    Would love to hear some of your thoughts on the three players.... :lease:
    Would help me clarify which model I end up buying.
  5. Jai
    Jai
    Bought the pioneer dv-575 (hyperfi £109). Then returned it the next day. Coz there is noticable edge flicker in the picture. tested it on a sony 32dx200 and a panny 28pm11 same results with 2 different scart leads. Can't comment on the other players in your list.
  6. MickyGee
    MickyGee
    Jan 6, 2005
    294
    Preston
    HD745 rocks on upscaled component and only £110 ! :clap:
