Pioneer 575 on a Videoseven 32" LCD - Help Me!
Discussion in 'Blu-ray & DVD Players & Recorders' started by JFKM, Jun 2, 2005.
  1. JFKM
    JFKM
    May 29, 2005
    362
    Somerset
    +39
    I'm hoping that someone has a solution to my problem - I've recently purchased a Videoseven 32" LCD tv, and a new Pioneer DV-575a DVD player (from Richer Sounds) for progressive scan goodness. I connected the DVD to the LCD with an Acoustic Research component cable. Interlaced mode looks fine, but when I switch the player onto progressive mode, the screen goes horribly green! The picture sometimes cuts out for a couple of seconds every now and again also. I've checked and double checked the connections; the DVD player is also on the most recent firmware version. No luck. I get the same effect on both PAL and NTSC progressive. Please tell me that someone has experienced this problem and can help me! Thanks (hopefully) in advance.
