Pioneer 575 multichannel connection advice
Discussion in 'Blu-ray & DVD Players & Recorders' started by noahjld, Oct 26, 2005.
  1. noahjld
    noahjld
    Oct 25, 2005
    10
    Hi,got the Pioneer 575 player & VSX 502 AV amp.Can someone explain (for a complete idiot!!) how to connect them up for multichannel sound etc.Which leads go where etc? Also I have a cheapo Acoustic Solutions speaker package with sub woofer.In the manual it says I can connect the speakers directly to the woofer & also connect the 575 outputs to the subwoofer too.Is this the best way or is it better to connect the speakers to the 502 speaker terminals & then just connect the 502 to the sub woofer via single plug phono lead.
    I have quite a few SACD's & DVD Audio discs so want best sound possible.Any help or info much appreciated.Much easier with ordinary CD players!!! :lease: :)
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,144
    +564
    For normal DVD surround sound (DD/DTS) - single coax(phono) or optical connector from the DVD player to your amp.
    For SACD / DVD-A - you need 6 phono to 6 phono to cope with the 5.1 channels independently - your amp should have some sort or "external 5.1 input" sockets.
    For speaker connections - the sub should be connected via single phono from the amp (presuming it's an active sub ie one with a built-in amp), the rest of the speakers should be connected to the appropriate speaker terminals on the amp...PJ
  3. GazH
    GazH
    Apr 17, 2004
    449
    On the corner of Wabash and Lake
    +77
    Hi noahjld,
    I have a set of AS150 speaker that I bought from Richer Sounds (Maybe the same as yours) and I plug the outputs from my 575 directly into the woofer connections and it works great...
    Not had a chance to play any SACDs etc through it (as I don't have any yet) but it is brill for DD5.1
    HTH
    Gaz
  4. noahjld
    noahjld
    Oct 25, 2005
    10
    Thanx for your replies,will have a go tonight.If I encounter any probs etc I'll post a message tomorrow!!! Cheers.
  5. rhino2k
    rhino2k
    Oct 20, 2005
    6,128
    +1,322
    best way to connect the dvd to the amp is via an optical digital cable :)
    i got some very good van damme ones from ebay, only around £14 each too :smashin:
  6. PJTX100
    PJTX100
    Dec 21, 2004
    8,144
    +564
    I thought the prevailing advice was coax for short runs and optical for longer runs?...PJ
  7. rhino2k
    rhino2k
    Oct 20, 2005
    6,128
    +1,322
    not sure, but i would have expected the optical to be better.....
    than again the jury is still out on HDMI afaik so not necessarily true :rolleyes:
    tbh i just like the neatness of an optical cable, small and tidy :cool:
  8. Sheltie
    Sheltie
    Nov 22, 2004
    56
    9
    Can someone tell me if the 575 will output on both digital coax and 6 channel out. i.e. can I connect up both to my av amp, so i use the digital output whilst watching dvd's and use 6 channel when listening to Sacd?
  9. Supersonic
    Supersonic
    Jan 5, 2005
    1,162
    Surrey
    +219
    Yes you can - that's how I connect to my Denon 2805. You'll have to switch the amp to the right input though ('Ext. In' in my case).
  10. Sheltie
    Sheltie
    Nov 22, 2004
    56
    9
    Thanks Supersonic, just what I needed to hear :thumbsup:
  11. noahjld
    noahjld
    Oct 25, 2005
    10
    :lease: Hi,thanx for you replies & here goes :- on the back of the 575 player are the following "audio out 5.1" sockets :-
    "front" "surround" "center"
    (2 phono L + R) L + R center L
    subwoofer R
    On the back of the 502 amp are the following "audio in" 5.1 sockets :-
    L center surround L
    R subwoofer surround R
    As you can see there are 3 sets on the 575 player but only 2 sets on the 502 amp!! I've connected up the 575's "surround" & "center,subwoofer" to the "surround" & "center,subwoofer" on the 502 but not sure where the 575's "front L + R" gets connected!!!!!! Any ideas help re connections,leads etc
  12. Slimchandi
    Slimchandi
    Dec 23, 2004
    486
    +3
    They are connected via a Scart socket from DVD player to your DVD input on the amp. Stupid isn't it?
  13. noahjld
    noahjld
    Oct 25, 2005
    10
    So basically I just need a "2 phono to scart" lead to connect the "front L + R" from the 575 to the 502 amp & leave the other sockets connected up as they are? Just gets more confusing!
  14. Slimchandi
    Slimchandi
    Dec 23, 2004
    486
    +3
    I think all you need is a single Scart cable. The audio from pins whatever in the Scart on the DVD should come out in the hires format. If not, you could use a Phono to Scart. But standard Scart should work. Give it a whirl. There may be a particular setting on the DVD player to enable the Hi-res audio through the Scart, anyone know more than me?
  15. trailer
    trailer
    Dec 22, 2004
    2,880
    +231
    if you have the 5.1 analogues and the digital connected then that is all you need. Forget the L and R that will come through the digital.
  16. Supersonic
    Supersonic
    Jan 5, 2005
    1,162
    Surrey
    +219
    There are several types of connection audio connection on the 575 as follows:
    Scart - this will provide stereo audio into your TV
    2 Channel - provides Left and Right sockets for connecting a normal audio interconnect e.g. going into a stereo amp.
    5.1 Analogue multi-channel - provides Left, Right, Surround Left, Surround Right, Centre and Subwoofer sockets for connecting multi-channel audio into a multi-channel receiver.
    Digital coaxial and digital optical - basically two choices for how to get digital audio stream into your amp/receiver.
    You can connect any and all of these but how they work depends on the settings of the player.
    Roughly, if you have:
    TV - use scart for picture and audio in one. Audio out setting to 2 Channel
    Amp/receiver - use either digital, stereo connection, or 5.1 analogue multi-channel connections.
    - Digital will provide stereo (e.g. from CDs) or multi-channel (e.g. Dolby Digital or DTS from DVDs)
    - Stereo connection will provide a normal analogue stereo feed
    - 5.1 analogue multi-channel connections will provide a multi-channel analogue feed, it will send decoded Dolby Digital or DTS from DVDs but is also necessary for the high-definition tracks on SACDs and DVD-Audio disks. (If you connect solely via digital, you will usually still get the Dolby Digital or DTS digital multichannel tracks if there are any, but not the high-definition part of the disk).
    I do the following:
    Digital coaxial connection to receiver - for DVD movies and CDs
    Stereo connection - straight to TV for 2-channel audio (because I use an s-video connection not Scart - not enough RGB scarts on my tv!)
    5.1 multi-channel analogue connections to the receiver's analogue multi-channel inputs - for dvd-Audio and SACDs.
    Hope that helps.
  17. Slimchandi
    Slimchandi
    Dec 23, 2004
    486
    +3
