Pioneer 575 make multi region
Discussion in 'Blu-ray & DVD Players & Recorders' started by Bikertone, May 6, 2005.
  1. Bikertone
    Bikertone
    Finally solved the problems visit this website and download the firmware may have to try a few to get one that works I used ref 1257.
    http://mtz.softpedia.com/index.php?...tid=70&Itemid=4
    unzip it, load the ISO file to a cd and stick it in the drawer. It should then start loading the updates.
    Region numbers will be listed under initial settings/options/country/region.
    Watch out for the format though may have to toggle between PAL and NTSC
    (see page 45 of the handbook)
    I had a problem with the resume function as well. Looks like it doesnt work with dvix but will on dvds.
