Pioneer 575 - Firmware
Discussion in 'Blu-ray & DVD Players & Recorders' started by OneEyedStuart, Nov 19, 2004.
  1. OneEyedStuart
    OneEyedStuart
    Oct 12, 2003
    4,995
    Lockerbie, Scotland
    +907
  2. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,357
    83
    +193
    Apparently it will according to an earlier thread regarding this - HOWEVER, I called Pioneer about this and the tech support a)knew nothing about it and b) commented I was the second person that day who'd asked. He disappeared and came back and said yes it will be available, took my details and said they'd call me when they had more details.
    Good job I didn't hold my breath - still heard nothing from them.
  3. OneEyedStuart
    OneEyedStuart
    Oct 12, 2003
    4,995
    Lockerbie, Scotland
    +907
    Thanks, I'll hold off then.
    KH
  4. rockyglw
    rockyglw
    Dec 15, 2002
    99
    +4
    No it will not kill your multi-region and RCE setting. I have upgraded with the latest firmware and not only has it solved the problems I was having with DVD AUDIO disks, but has not changed multregion facilities. Go ahead and upgrade, but do use the official firmware available from Pioneer or on www.avland.co.uk/pioneer/dv575/dv575.htm site. Avland even state that multi region remains unchanged! :thumbsup:
  5. Seth Gecko
    Seth Gecko
    retired member
    Oct 9, 2004
    3,357
    83
    +193
    I sit corrected (although I was only quoting what was said by someone else on an earlier thread).
    I'm more mystified that I can download it from AVLand's site - but still nothing from Pioneer themselves :eek:
  6. Cool-hand
    Cool-hand
    Jan 5, 2002
    2,116
    Portsmouth / Middle East
    +77
    Very good having a firmware upgrade on a £150 player... I don't think even Arcam are this responsive! Does the FW UPGrade work or did you encounter any problems?
    CH
  7. rockyglw
    rockyglw
    Dec 15, 2002
    99
    +4
    As I said it worked 100%, did not have any problems. Emailed Pioneer who sent firmware on CD-ROM within 3 days. Just a case of putting disk in player and selecting play when requested. Settings such as RGB have to be reset as machine returns to factory defaults, except multi region that is. Superb value for a player that cost me £119 from Richer sounds. :)
  8. Cool-hand
    Cool-hand
    Jan 5, 2002
    2,116
    +77
    Hi again.
    I downloaded the firmware upgrade this afternoon and used nero to burn an image. All very easy and worked completely. Disc spins for about .1 of a second then takes a few minutes to complete the upgrade.
    I now find certain RCE discs play straight away and are not so hit 'n miss!!
    Thanks Keith
    CH
  9. nwgarratt
    nwgarratt
    May 5, 2002
    27,152
    +3,022
    Is there anything else that this firmware does/improves?
  10. Dillz
    Dillz
    Feb 25, 2004
    236
    Gloucestershire
    +8
    I believe the main improvement is that you can now see divx subtitles, and it seems to switch on quicker (or is that my imagination!)
  11. OneEyedStuart
    OneEyedStuart
    Oct 12, 2003
    4,995
    Lockerbie, Scotland
    +907
    Thanks for all the updated information guys. I have downloaded the firmare from avland. will burn it to disc later.
    KH
  12. Pug72
    Pug72
    May 10, 2003
    2,087
    Hereford
    +311
    I can also report that I did the upgrade without a hitch.
  13. OneEyedStuart
    OneEyedStuart
    Oct 12, 2003
    4,995
    Lockerbie, Scotland
    +907
    Thanks for all the confirmation guys, upgraded the player's firmware with no problems.
    KH
  14. chic
    chic
    Jul 1, 2001
    5,985
    glasgow
    +871
    what is this player like with divx files, i have lots of avi files of tv shows on my computer, can i play thes on this player, if so do i just burn them to cd or dvd as avi files and the player will autimatically play them
  15. rickardl
    rickardl
    Sep 9, 2004
    744
    46
    Stockholm
    +127
    Yes, if you press Play, it will play them in directory order.
    If you press MENU, you can navigate to which avi you want to watch.
  16. chic
    chic
    Jul 1, 2001
    5,985
    glasgow
    +871
    cool thats just what i need, just need to find anyone with stock
  17. OneEyedStuart
    OneEyedStuart
    Oct 12, 2003
    4,995
    Lockerbie, Scotland
    +907
    try multiregionmagic.co.uk
    they are more expensive than most others out there for the 575 but they do have stock.
    Regards
    Keith Hurst
  18. chic
    chic
    Jul 1, 2001
    5,985
    glasgow
    +871
    managed to reseve one at a richer sounds store , pick it up tomorrow
  19. OneEyedStuart
    OneEyedStuart
    Oct 12, 2003
    4,995
    Lockerbie, Scotland
    +907
    That'll be the one nr the St Encoh's centre then. I remember getting my first SubWoofer from there, an Eltax A-12R, then trying to carry it all the way beck to Queen Street. Needless to say I got 20 yards before going back to the shop and asking them to call a cab for me :laugh:
  20. NX3
    NX3
    Dec 4, 2002
    3,492
    103
    +8
    The new firmware also adds ogg support as well as subtitle to divx.
  21. chic
    chic
    Jul 1, 2001
    5,985
    glasgow
    +871
    that was my first port of call, but they are not getting any in till wednesday, i managed to reserve one in the liverpool store as my brother is in liverpool tomorrow and he can get it for me
