Pioneer 575 discontinued?
Discussion in 'Blu-ray & DVD Players & Recorders' started by simonali, Apr 22, 2005.
  1. simonali
    simonali
    Jul 5, 2004
    61
    Just been looking at the Pioneer UK website and only the 868, 757 and 668 are shown on there. are the lower models being replaced?
    (and if so, does anyone know where I can get a cheap 575 MR in black? You can get silver ones for less than £100, but not black)
  2. simonali
    simonali
    Jul 5, 2004
    61
  3. bbasra
    bbasra
    Sep 15, 2004
    1,600
    48
    Hounslow
    +34
    Just spoke to Pioneer CS, and the DV-585A is the new replacement and due in July 2005.
  4. Leerock
    Leerock
    Dec 26, 2004
    273
    19
  5. rickardl
    rickardl
    Sep 9, 2004
    684
    46
    Stockholm
    +127
    I believe the DV-575 can play DVD+R DL alltough not specified anywhere.
    Specwise, these are the only diffs I can find: (sorry for the bad formatting)
    DV-575 DV-585
    Total Harmonic Distortion: 0.0020% 0.0023%
    Power Consumption: 12W (0.18w Standby) 8W (0.18w Standby)
    Height: 55mm 49.5mm
    Depth: 243mm 214.9mm
    Weight: 2.1kg 1.8kg
    smaller, lighter and less power consumption but sligthly higher thd.
  6. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    By the time they get to the 595 it will be the size and weight of a DVD case!
    ...PJ :)
  7. NX3
    NX3
    Dec 4, 2002
    3,488
    103
    +332
    Hopefully the 585 will support packed bitsteam divx as well unlike the 575.
    Leerock, got any info on upcoming DVD-Recorders from Pioneer? One with a freeview tuner would be good :)
  8. rickardl
    rickardl
    Sep 9, 2004
    684
    46
    Stockholm
    +127
    the short story: In June 2005
    DVR-433H (499 €, 80 GB HD, Juke Box, PAL Progressive),
    DVR-530H (599 €, 160 GB HD, Juke Box, PAL Progressive)
    DVR-630H (799 €, 250 GB HD, Juke Box, PAL Progressive)
    the longer story:
    It is in German but contains a *lot* of info about the new recorders:
    http://www.areadvd.de/hardware/pioneer_dvd_rec_juni_2005.shtml
  9. NX3
    NX3
    Dec 4, 2002
    3,488
    103
    +332
    Thanks rickardl, hope the UK get a digital tuner model and can use the EPG.
  10. scrapbook
    scrapbook
    Jan 12, 2002
    7,115
    +527
    Other than how ugly and cheapo looking it is......yuk
    When are Pioneer going to produce a £200 - £300 player with HDMI???????????
  11. Crespotav
    Crespotav
    Feb 27, 2005
    49
    Kimpala
    The 668AV-S can be found at redcoon for the equivalent of £390. Does not ship to UK, though.
    Also HDMI, by itself, means little. The 668 only outputs only 720 x 480HP (NTSC) and 720 xi 576P (PAL). This is not high definition TV. To get the Complete HDMI (High Definition.....) you need the 868.
