Pioneer 575 and Panasonic PD30
Discussion in 'Blu-ray & DVD Players & Recorders' started by Hybe, Aug 15, 2004.
  1. Hybe
    Hybe
    Jul 26, 2004
    15
    Strängnäs, Sweden
    anyone tried the combination?
    I've heard previous roumors of problems when viewing through the component-channel (and PS), with Pioneer DVDs and Panasonic TVs...
    can anyone confirm?
  2. ktng
    ktng
    May 9, 2004
    174
    16
    UK
    No problem with my 575A/PD30 using progressive scan via component.
  3. Hybe
    Hybe
    Jul 26, 2004
    15
    Strängnäs, Sweden
    great!
    anyone else?
  4. scrapbook
    scrapbook
    Jan 12, 2002
    7,422
    +550
    Didnt the problem with Panny TV's and Pioneer DVD players revolve around the RGB output?
  5. Hybe
    Hybe
    Jul 26, 2004
    15
    Strängnäs, Sweden
    hmmm, maybe...!
    however, I'm only asking cuz I saw some thread at a swedish forum, when a guy asked the same thing as I did! :)
  6. riku
    riku
    Oct 9, 2001
    19
    finland
    I just bought a 575 and connected it to my PW6 using component (through a Denon AVC-A1). No problems at all - either interlaced or progressive. Player is fantastic btw - plays all my home made divx dvds too :)
    Richard
  7. Mungo
    Mungo
    The picture from my Denon 2200 into a PD30 is fantastic. The picture from my Pioneer DVR5100 through a £40 Thor SCART on RGB is poor. You would expect that as the Denon is PS and component but its also a poorer picture than from my old Toshiba 220 into a 9 year old Toshiba 25" TV.
    So the message from me is that care is needed and you should probably demo them together to make sure you're happy.
  8. Face
    Face
    May 15, 2004
    88
    +14
    Yep, fine here too. The only thing I have noticed is with the Interlaced signal, when a red colour is showing, there are what appear to be interference lines visible. Having said this, you'd need to look for them, and most of the time with a normal film/tv prog, you'd never notice them.
    Maybe I noticed them because I'm sure I read about it elsewhere. A more expensive component cable might help, but then I did spend £50 on my Profigold cable.
