Pioneer 575 and analog inputs
Discussion in 'Blu-ray & DVD Players & Recorders' started by saibot, Nov 11, 2004.
  1. saibot
    saibot
    Jun 28, 2004
    1,240
    Near the Lee - Ireland
    +42
    Plugged in the 6-analog leads last nite from pioneer 575 player to my marantz 6200 amp, ( for sacd/dvd-a). However when I play a dvd-video ( with the leads plugged in ) , audio from the movie seems to be coming through the analog connections as well, and its extremely loud !!!
    Have I set some-thing incorrect?? Has any-one else had this issue...
    ta,
    d...
  2. Mr Ess
    Mr Ess
    Oct 27, 2004
    1,303
    48
    Preston, Lancs
    +39
    Well, you're one step ahead of me. I have just setup my 575 player with an optical and analogue 6 RCA lead conenctions to my Denon 3805 and when I try to play a DVD-Audio disc it doesn't play ANY sound. Its only when I go into the initial settings menu and change the DVD-Audio setup to play as DVD-Video does it come out as DTS.
    Maybe someone can shed some light onto how these pioneers should be setup.
  3. saibot
    saibot
    Jun 28, 2004
    1,240
    +42
    Do'h I think I might have just noticed a mis-config in the cabling :suicide: , will check it out, and get back if I need more assistance....
