Pioneer 565A and SCART autoswitching?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Ono, Oct 31, 2003.
  1. Ono
    Ono
    Oct 18, 2000
    1,410
    London
    +101
    I've connected my new Pioneer 565A to my Sony TV via a full pin SCART lead and it doesn't autoswitch the TV when I play a DVD.
    It autoswitched fine with my old Sony DVD player with exactly the same leads so it I reckon it's the DVD player.
    Is there a setting I need to turn on in the options or something. I've had a look and also tried the manual and can't get it to work.
    Outputting RGB to the TV.
    Any ideas? Anyone have a 565A and get autoswitch?
  2. Cadire
    Cadire
    Oct 18, 2003
    146
    Sussex
    +10
    Works fine here.
    I don't recall having to select an option to enable it though, it just works.
    Having said that, I would have thought that autoswitching would be set up on the TV (that's from a novice's perspective btw, so don't take it as gospel :)).
  3. Ono
    Ono
    Oct 18, 2000
    1,410
    London
    +101
    OK - cheers.
    Maybe it's just that I haven't pushed the SCART connectors in hard enough.
    Can't be arsed to check it now. Gonna take the whol system apart and rewire tomorrow anyway.
  4. Ono
    Ono
    Oct 18, 2000
    1,410
    London
    +101
    Sorted now.
    It was the SCART switcher going into the passthrough SCART that was messing things up.
    Cheers.
  5. OneEyedStuart
    OneEyedStuart
    Oct 12, 2003
    4,871
    Falkirk, Scotland
    +832
    Ono,
    I have the 565 wired into the tv via rgb cart. It auto switches fine. I have however noticed a slight funny with the machine.
    I have my sky box pluged into the 565's second scart input and use this as pass through to the tv when the 565 isn't playing discs. Allows me to use rgb on the sky as well as the 565 as my tv only allows one rgb scart input.
    What I have noticed is if when playing a disc the aspect ratio on the sky box changes then the aspect ratio on the playing film changes to match. Most odd. What I tend to do now is turn off the sky box when playing discs.
    An inconvenience but not a major one.
    Keith
