Pioneer 565
Discussion in 'Blu-ray & DVD Players & Recorders' started by Rickyj @ Kalibrate, Sep 18, 2003.
  1. Rickyj @ Kalibrate
    Rickyj @ Kalibrate
    Well-known Member AVForums Sponsor
    Jan 29, 2003
    5,849
    Surrey
    +1,846
    Could anyone advise me on how the above DVD player performs using the inbuilt bass management. I am paticularly interested in the performance with both SACD and DVD-A, as am using the KEF 2005.2 speaker package, through a sony reciever (which when in the next couple of months will be replaced by a pioneer).
    Thankyou
    Ricky:D
  2. JUS
    JUS
    Jan 21, 2003
    3,432
    Plute
    +319
    I don't have a sub at the moment so I have it set to "sub off". The only settings I have seen in the menus are to do with
    1. Do you have a sub
    2. how loud do you want it to be compared to the other speakers. I haven't seen any settings in manual or on the screen from crossover etc.
    I'll check later but I'm pretty sure those are the only ones.
    Regards,
    Justin.
  3. Bapapapa
    Bapapapa
    Jul 24, 2000
    113
    16
    You can specify large or small speaker settings - no idea what the crossover is set to though..
