Pioneer 565 or 656
Discussion in 'Blu-ray & DVD Players & Recorders' started by stuart1974, Sep 26, 2003.
  1. stuart1974
    stuart1974
    May 23, 2002
    7
    Its probably been done to death, but!
    Should I get the pioneer 656 or the 565. They're fairly similar price but I can't figure out which one is better. Obviously the 656 is going to be harder to get hold of though,
    Any Ideas?
  2. andymc
    andymc
    Sep 18, 2003
    261
    Bedford
    +15
    The 565 has just been voted DVD of the year in the What Hi Fi 2003 awards and can be had for as little as £179 from Richer Sounds...
    I have bought one to use for SACD playback - waiting to try it as a DVD player so will let you know how it performs
    Andy C
  3. NinjaKi11a
    NinjaKi11a
    Sep 7, 2003
    314
    16
    Apparently 656 doesn't do NTSC progressive...
  4. phil5743
    phil5743
    Apr 13, 2003
    401
    28
    Ongar, Essex
    +27
    565 also plays Jpeg files
  5. Garrett
    Garrett
    Apr 21, 2001
    31,442
    2
    The best thief you’ll never see.
    +4,031
    I think at that price it will be a non multi region player.
    I just got one today and the picture is absolutely cracking I though how could they improve on my old player but the amount of detail is stunning.:smashin:
    I just having a bit of trouble with the sound set up at present here . But I had that with my old one till I got it sorted.
  6. Garrett
    Garrett
    Apr 21, 2001
    31,442
    2
    +4,031
    You just reminded me I had a X-Men CD freebie with the Times, It would not play on my Grundig 210, it would play on my parents Tosh 330 but not perfect. Just been and put it in the 565, it brings a menu up and plays spot on. All very professional.
  7. nealgs
    nealgs
    Is it worth upgrading from a Pioneer 525 to the 565 then without a display device upgrade??
    We've got a Panasonic Tau 32" PF10, no component/no progressive - single RGB enabled SCART (others are S-Vid). Would it be worthwhile upgrading based on this at all?
    cheers
    Gary
  8. kdp99
    kdp99
    Mar 29, 2001
    196
    Southampton,Hants,UK
    +20
    Gary
    I am using the 565 with a 32Pf10, and the intermitent vetrical ringing occurs on RGB, S-VHS is fine.
    Keith
  9. nealgs
    nealgs
    kdp99,
    cheers for reply - what's this vertical ringing you mention??
    Gary
  10. kdp99
    kdp99
    Mar 29, 2001
    196
    +20
    On this forum there is a thread about 565 problems a couple of pages ago that discusses it.
    I got the 565 for the DVD-A / SACD and use the SVHS feed.
    Keith
