Pioneer 565 low bass output on SACD?
Discussion in 'Blu-ray & DVD Players & Recorders' started by They, May 27, 2004.
  1. They
    They
    Sep 10, 2002
    171
    16
    Bristol
    Has anyone with a Pioneer 565 DVD player had any problems with poor bass level output when listening to SACD and DVD-Audio via the 5.1 analogue outputs?
    The bass on mine seems very low, even when I turn it up to +10dB on the Marantz 5400 and crank up the volume on the sub.
    Any suggestions? Is there a known fault or remedy? :lease:
    Thanks.
    David.
  2. chris
    chris
    Nov 20, 2000
    1,226
    romney marsh, kent, uk
    +28
    Do a search and you should find all the answers you could possible want.
    It has been disscused many, many, many times before..... :eek:
