Pioneer 565 Component Out PS only?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Spencem, Oct 28, 2003.
  1. Spencem
    Spencem
    Oct 15, 2001
    197
    Northampton
    +9
    I'm looking to get one of these to replace my ageing Tosh9000 and have something to play multi-chanel audio on, but having just read the review in this months HCC they say that the component outputs only work when running in PS. Could someone who has a 565 please confirm if this is true?
    It may not be a problem anyway because of the RGB pass though on the second scart, but I would like to continue to use the component in on my PF1.
    Thanks in advance.
  2. Cadire
    Cadire
    Oct 18, 2003
    146
    Sussex
    +10
    I have one of these and the component out does seem to only work with PS.
    Saying that, I have yet to get it working with PS on my Tosh 36ZP38.
  3. Badger
    Badger
    Jan 21, 2002
    259
    The menus suggest it can be switched between interlaced and progressive component output but I havn't tried it yet
    Phil
  4. Cadire
    Cadire
    Oct 18, 2003
    146
    Sussex
    +10
    That's the bit that confuses me. It suggests that PS should work in two ways, but the manual doesn't explain what these ways are. It only states that if using progressive causes the screen to go blank, then switch it back to interlaced. Could it be that those options are actually fancy names for 'On' and 'Off'?
  5. S H A D O
    S H A D O
    Mar 16, 2001
    10,369
    United Kingdom
    +1,737
    If it's anything like my Toshiba you need to have the Video output set to Video or S-Video to get a picture from the Component Outputs. Setting it to RGB disables this output. You should also be able to toggle between Interlaced and Progressive for the Component Outputs.
  6. Cadire
    Cadire
    Oct 18, 2003
    146
    Sussex
    +10
    Disabling RGB does indeed allow the PS to work... sort of.
    On my TV it's as if the whole picture is bigger than my screen, i.e I can only see a part of the picture.
    Maybe it's to do with the fact I'm playing a PAL R2 DVD and trying to convert to NTSC? The TV is supposed to be able to handle both formats though.
  7. Cadire
    Cadire
    Oct 18, 2003
    146
    Sussex
    +10
    Further to this.
    It looks like the options are indeed PS Off and On.
    With 'Interlaced' (and RGB disabled) the connection is a normal component one.
    With 'Progressive' (and RGB disabled) the connection is an NTSC PS.
    With RGB enabled, Component output doesn't work.
    So, looks like the mag was wrong, as component connection does work without PS.
    It's worth leaving a scart in though, as you can't see the menu if you change back to RGB.
  8. Spencem
    Spencem
    Oct 15, 2001
    197
    Northampton
    +9
    Thanks for the info, and for trying it for me.:smashin:
  9. Steve Amos
    Steve Amos
    Cadire,
    What happens if you play a PAL DVD when it's set to Progressive?
    Does it ouput 'Interlaced' PAL or does it convert the output to NTSC?
  10. Cadire
    Cadire
    Oct 18, 2003
    146
    Sussex
    +10
    One of two things happen Steve.
    Either the picture is too big to fit on the screen, and there's an 'empty' bit at the top/
    Or, after resetting to 'Auto' from Pal, I get a nice picture (NTSC) with dropped frames.
    Apparently the dropped frames don't occur with NTSC DVDs.
