Pioneer 565 and RGB mode
Discussion in 'Blu-ray & DVD Players & Recorders' started by Vodder, Jan 29, 2004.
  1. Vodder
    Vodder
    Jan 11, 2004
    449
    16
    London, UK
    +8
    Don't know if this is the right part of the forum but...
    When switching to RGB from video mode on the DVD player, the resolution becomes extremly better (like it should) however the whole screen moves to the left. So much so that I actually can't see about 1cm as its off the screen. If I revert back to video mode then I can see everything again.
    Exactly the same happens with the freeview box, if I switch RGB on then part of the Sky News clock disappears.
    Could it be the fact that its all currently rigged up to a normal 4:3 28" Sony? The scart socket on the TV is RGB enabled. Any ideas?
  2. Zacabeb
    Zacabeb
    Jan 17, 2002
    474
    +9
    This happens on lots of TV's and it is caused by the RGB signal getting its synchronization from the composite signal in the SCART cable. The synchronization must first be separated from the composite signal, and before (and while?) this happens, it may get delayed. As a result, the TV starts drawing each line a little too late, making the RGB picture itself start drawing 'too early', i.e. further to the left.
    Some TV's compensate for this and some don't, but it is a common problem. It's probably more common on 50Hz sets, since 100Hz sets may easily compensate for this in their digital processing.
  3. Vodder
    Vodder
    Jan 11, 2004
    449
    16
    London, UK
    +8
    Cheers for the info.
    Its quite an old TV, so I don't know the refresh rate.
    Is there anything I do about it? Apart from buying a new TV!
    If I get a widescreen TV will that stop the prob, or is it all down to the refresh rate?
  4. Zacabeb
    Zacabeb
    Jan 17, 2002
    474
    +9
    Newer TV's may still have this problem, even 100Hz sets I think. The best way if you want to buy a new set, is to find out if the problem is there by actually testing it in the store.
    I don't know what can be done about it on your set. If you won't use non-RGB sources much, an engineer may be able to adjust the set so that the screen is optimally centered with RGB input.
  5. Vodder
    Vodder
    Jan 11, 2004
    449
    16
    London, UK
    +8
    Bummer - looks like its normal video mode from now on then...
  6. Garrett
    Garrett
    Apr 21, 2001
    39,866
    2
    167
    The best thief you’ll never see.
    +6,525
    You could always draw up a short list of TV's and ask the guys on the forum if they have the same TV and DVD player if there are any compatibility problems.
    I seem to remember some one saying Pioneer and the Panasonic caused problems and body else remember this post?
  7. Johndl
    Johndl
    Feb 27, 2002
    323
    S Devon
    +16
    I've got a 50" Sony RP and find the problem more complex. All my connections are RGB. On dvd the pic is always correctly placed. From Sky+ it is mainly correct, but lots of anomalies. The main news in the studio is correct, with outside broadcast offset. The local news is all offset. Most other programs are correct. So it seems also to do with how it's broadcast.
  8. Vodder
    Vodder
    Jan 11, 2004
    449
    16
    London, UK
    +8
    My brother has a Sony 28" widescreen, don't know what model, but when he runs the Sky box on RGB everything is absolutely perfect.
  9. Garrett
    Garrett
    Apr 21, 2001
    39,866
    2
    167
    +6,525
    I run my 565 on a Loewe OK and my last player (Grundig) on a Sony and Panasonic both on RGB. But as I say I seem to remember them being some issues with the Pan and Pioneer and each was blaming the other.
    Mind you it could have been a one off which is more than likely.
  10. Stew
    Stew
    Feb 1, 2003
    52
    will an RGB only scart lead correct this problem?
  11. Kevo
    Kevo
    Aug 23, 2001
    5,397
    Manchester
    +149
    For the sake of 1cm superior RGB :confused:
  12. Vodder
    Vodder
    Jan 11, 2004
    449
    16
    London, UK
    +8
    I know 1cm doesnt sound a lot, but it makes the freeview really bad, you get a big white streak down the right hand side and I ain't sure that will be doing the TV anygood.
    I've enabled it on the DVD player though, as it doesn't seem to effect the film too much and I haven't found a menu yet that isn't all in the middle.
  13. Garrett
    Garrett
    Apr 21, 2001
    39,866
    2
    167
    +6,525
    For the 1 cm you could always go into the service menu an stretch the screen out if your bothered about the black line but then you will miss 1cm at the other side.
    Or move the picture horizontally but will have the black band on the other side on normal TV.:(
  14. kev3
    kev3
    Mar 3, 2003
    74
    I am experiencing the same problems..
    I've got a newish tv a Panasonic TX-32PB50 its 100Hz.
    1 cm is'nt a lot, but its annoying as hell to think you're not getting the best out of your new dvd player!
    Anyone got any more information on this?
    Or a way to correct this?!
    Cheers.
  15. scrapbook
    scrapbook
    Jan 12, 2002
    7,411
    +550
    My brother has a Sony KV32FQ75 now replaced by the FQ80 (I assume?)
    Anyway the instruction booklet for this model specifically mentions the RGB jump to the right scenario and has the ability to adjust accordingly just for that particular RGB input.
    Hope that helps!
  16. HMHB
    HMHB
    Nov 11, 2001
    26,637
    Nottinghamshire
    +5,351
    Ive got the 565 and the Panasonic TX-32PB50 and do not get this problem. So it must be fixable. I'm using an RGB only scart lead - can't remember the make of it but it cost about £50 and was recommended by the mags at the time.
  17. Ged
    Ged
    Apr 29, 2002
    943
    +24
    After messing around with this player and my Panasonic tv I have noticed that when a PAL disc has been played the RGB seems to be centred but insert an NTSC disc and off it ( the player's menus ) goes to the left, bob in another PAL disc and problem solved.
    I do unfortunately have to watch NTSC disc via S-video due to a strange line type effect.
    I bought this player to replace a Sony 900v for more relliable DVD-R and SACD/DVD-A, unfortunately it seems I still need to use them both, so not such a "universal" player.Shame really.
    Ged
  18. bob1
    bob1
    Nov 7, 2002
    4,458
    Sheffield
    +131
    I sent off for this player the other day(not got it yet)anyone got any probs with a philips tv.
  19. Ged
    Ged
    Apr 29, 2002
    943
    +24
    This line problem was something I retuned a Mico player to Sainsbury's for, I wonder if they are of the same production line?
  20. Vodder
    Vodder
    Jan 11, 2004
    449
    16
    London, UK
    +8
    Well I don't know what I've done but its fixed!!! Perfect RGB picture centred on the TV via DVD or the Freeview box!!! :clap:
    I've now connected my VCR, DVD and the freeview via all the scart sockets using the loopthrough method, and now when the VCR is switched to line 1 - the TV shows perfect RGB when set to RGB mode!!!
    :smoke:
  21. kev3
    kev3
    Mar 3, 2003
    74
    I'm using a decent Ixos RGB scart, but still get this prob, anyways..
    I managed to get into the service menu of my TX-32PB50, moved the picture to the right a bit.. Solved my probs!
  22. BAD Dave
    BAD Dave
    Sep 16, 2003
    475
    Dundee
    +18
    I have been thinking of buying a Pioneer 565 DVd player for a while now.
    Does anyone know whether or not I am likely to experience R1 RGB banding problems with my Panasonic TX-32DK1 TV?
