S
stephenbelcher
Has anyone managed to fix the horizontal banding problem with region 1 disks and RGB? I found this which might fix it can someone try it and let me know before I go and buy another 565. Thanks
The TV engineer has just left after curing the scrolling interference
pattern seen when watching DVD via RGB. The problem is known to Panasonic. The cure is an adjustment to the "Digital Voltage Control Oscillator" (DVCO).
The DVCO is altered via the service control menu, this menu is accessed by:
> Bass to Max
> Treble to Min
> Press Prog Down on TV and Index on the remote
> Red or Green button navigates the menus
> Yellow or Blue button alters values
> Store to save changes
> End to leave
> Bass to Max
> Treble to Min
> End to leave
