Pioneer 545 remote control
Discussion in 'Blu-ray & DVD Players & Recorders' started by prel2000, Jan 4, 2007.
  1. prel2000
    prel2000
    I read somewhere that a better version of the remote control could be purchased. Does anybody have any details i.e. model number, where available etc etc.
    Thanks in advance.
  2. leocohen
    leocohen
    I considered getting the remote from the 530, but apparently it does not work properly - the colour keys do not work, and they are crucial for navigating the guide.
    I am now thinking of getting the remote for the 940, which has a considerably better lay-out, but I am not sure it will work mainly because there is a jog dial which might not be supported by the other units.
    Has someone out there tried a 940 remote with a 440/540/545 unit?
    Leo
  3. prel2000
    prel2000
    Anybody else have any thoughts on this...?
  4. cobson
    cobson
    Aug 1, 2005
    45
    You could use a programmable remote, eg a Logitech Harmony
  5. foneman
    foneman
    Mar 25, 2005
    1,104
    48
    south london
    +23
    If someone has the remote, can they please submit a picture, or describe what function the color keys do?? I have the manuals downloaded, but only the 530 DVDR... :thumbsup:
    I just had a quick look at mine, it does have the color keys for guideplus... model no. is VXX2969, if you want to order...
    Red=audio, Green=subtitle, Yellow=angle, Blue= Playmode
    If you have these function keys elswhere, they could work... it depends whether you can do with just EPG...
  6. bradavon78
    bradavon78
    May 31, 2004
    3,202
    South West, England
    +133
    Old post I know but I wouldn't say that. The 940 and 550 share the same remote and while it's a definite improvement it's still nowhere near as good as the 530, and crucially still has that ruddy flap.
    When watching TV I use the number buttons to quickly navigate around, this is a right pain when they're under the flap :mad:
  7. mray
    mray
    Feb 16, 2004
    2,772
    83
    London
    +234
    Hi.
    The colour keys are used to program a timed recording I believe. I haven't found the need to use them for anything else. Every other function works. Plus, if you need timed recordings, you can always dig out the old remote, if need be:smashin:.
